I agree. I think most of the failures have to do with off roading in mud and water holes and also driving on salty roads where corrosion causes the vent to seize shut. i could see where cheaper axle seals could be an issue too if that is what happened in the past. there is a good chance of that since the titan had issues with seals of low quality....anyways if anyone can get 200k out of the seals without leaking then there is no seal problems or axle vent problems either which leads me back to off roading through mud and water and salt corrosion as being the main cause of the failures.
how a truck is treated has a lot to do with things. some people will have a clutch go out at 50-75k miles so they say it's a bad clutch design...but then someone else will drive the same clutch for 250k miles without any issues. so is it a clutch problem or a driver problem? LOL
you can't treat a truck like crap flooring the gas pedal everywhere you drive and tear it up off roading and spinning the tires all the time etc. and expect it to last 500k miles trouble free. that just doesn't happen.
This ☝☝☝☝☝☝☝
Very well said and I feel the same way. It just makes no sense how many of these trucks are on the road, not just Frontiers but Titans (same vent design and axle) and so many have well over 100k miles with no issues and then some people have 30k miles on their truck with leaky seals? Just doesn't add up to me.
To those that want to do the mod, no one is saying for you not to. I am not mocking this mod or telling you NOT to do it. My whole point for me to bring this thread back up is the opinion is the vent itself being faulty is the reason for the failures and by doing this mod it will eliminate the problem. Fact is? It won't. You can look on different forums just like I have and see that people WITH the mod still had failures. I am just a curious cat and I like to figure things out. Like I said earlier I think I missed my calling and should have been an engineer. haha I just like to know how things work and if and when something does fail? I want to know why and see how to prevent it happening to anyone else.
In the research I have done thus far? Honestly? It seems in the earlier years of the trucks they just had a crappy seal design. The seals were upgraded at some point, but people being cautious just did the mod anyway. That is fine. For me? I want to go deeper into it and see what REALLY happened.
The fact that people are having leaking seals WITH the mod and Without, and with a functioning OEM style vent leads me to believe there is more to this than we know.
Questions is? Is this STILL an ongoing problem? or not? Most of the "failures" i have read about are trucks that are either A) are modified B) have over 100k miles and C) are 2005-2010 model years.
So is this a current problem? That is the question.
Thanks Everyone for your input, love the topic its interesting to me, and enjoy all your input.
I will post more info as it comes available. If you find out some info PLEASE share it here .
Maybe I can begin a post, as a sticky if the admins will allow, to have people post if they have had an axle failure yes or no, give some info on their trucks and we can sort this out ourselves. Like a poll type of thing?
I will look into doing that. Get some good data that way 👍
