621 - 640 of 641 Posts
1. Engine knock in some trucks. Not just at start-up.
2. Noise in dash, like a finger taping the dash somewhere.
3. Squeaks, Dash
4. Rubber around door rips near door catch
5. Design flaws (in my opinoin), Center arm rest is back to far & too low. Side mirrors control on dash, should be on door, like a Titan. Only drivers door can be opened by the key(2010 anyway). Gas shuts off when filling tank several times each fill-up. But They LOOK Great!:)
I bought my 2016 Frontier ProSport because I liked the looks of it…. I didn’t know anything about it at the time.
Lets not forget the rear axle vent piece-o-crap ( thanks DANA Industries ), and the SMoD and timing chains on early models. Other than that, it's a great truck and I've loved every minute of it. Would not trade for any other manufacturer or model, except maybe an early Land Rover, still have a soft heart for early British stuff.
owns 2014 Nissan Frontier Pro4x
Do you top off the tank when filling up?
no doubt. since they remedied the SMOD about 2009 i don't think you could go wrong with one of these trucks. i drove mine for 12.5 years and i think i'm about to sell it for ~10k less than i bought it. what a deal.
I'll pass on early British electrics especially the MG.
Oh, I never said the Prince of Darkness, Lucas Electrics, made anything decent. I just said I like old LR's. ROFL.
Reactions: gunn308
2014 Nisson Frontier, When driving my hood seems loose like too much slack an it's kind of flapping a bit or moving like it isn't shut tight and I was fearing it may fly open. I checked it, it was latched but too much slack. I even cut 2 small pieces of black pool noodle and then cut those length wise half way and slid them on the edge of the hood before closing to take up some of the slack but is there a way to get my hood to latch tighter without having to drive with pool noodles lol? Has anyone else had this problem? I only just bought it a couple of months ago.
Loosen the bump stops on the hood. That will take up the slack.
What shape are your rubber hood stops in? Is weather seal in good condition? Or might be able to adjust hood latch. View attachment 400078
Thank you for the response and information and especially the photo's. I will have to check a
L that out in the morning. I don't understand the photo with the really large circle. Would you please explain more. I guess you should use the simplest terms possible because I have no mechanical knowledge and this 2014 Nisson is my very first truck ever and iv only had it a couple of months. So far I love it and by the way I have another quick question...How come I can't get but like 2 music stations on the factory radio and one of them is Spanish but I can get in any other vehical and have no problem? I tried all the modes including FM 1 and FM 2 and no luck
It’s weatherstripping runs across front of hood, as for radio possibly bad antenna? You may be able to adjust the latch by loosening the bolts circled and push/tap downward. Also like grumpy said you can turn the bump stops counterclockwise a little to lower them.
When its cold outside and i go to fill up. My nozzle makes a "Gush" sound and then spews fuel all over my hand and down the side of my bed. Its done this 4 times in the last week.
Is it just because of the pressure building up from the cold weather and when i turn on my vehicle and drive. The pressure rises and when the pressurized air is let out. Or am i missing something...???
Same thing with mine, I’m not certain but aside from being a gas guzzker, if u just let it breathe a few before pumping? Won’t happen
