Brake TSB NTB06-037c
Has anyone had this done? My truck has the loud squeak and it's VIN is a part of the TSB...
Brakes - Squeaking From Front/Rear Brakes Classification: BR06-006c Reference: NTB06-037c Date: October 27, 2006 2005 FRONTIER AND XTERRA; SQUEAKING NOISE FROM BRAKES This bulletin amends NTB06-037b. Parts Information has changed. Please discard all previous copies of this bulletin. APPLIED VEHICLES: 2005 Frontier (D40) 2005 Xterra (N50) APPLIED VINS: Frontier built before: 1N6(*)D07(**)5C461154 Xterra built before: SN1AN08(**)5C651886 APPLIED DATE: Vehicles built before August 15, 2005 IF YOU CONFIRM A squeaking noise coming from the brakes. ACTIONS Perform all the repairs as follows: Front Brakes 1.Replace the front brake pads. 2.Install the new brake pad hardware kit (which includes new shims). Rear Brakes 1.Replace the rear brake pads. 2.Install the new brake pad hardware kit (which includes new shims). IMPORTANT :The purpose of "ACTIONS" (above) is to give you a quick idea of the work you will be performing. You MUST closely follow the entire Service Procedure as it contains information that is essential to successfully completing this repair.
George 2005 SE CC Radiant Silver V6 4WD|ScanGaugeII|Volant CAI|SilverStar Ultra headlights|AVS Bugflector II & Ventvisors|OEM Foglights|Custom Exhaust w/MagnaFlow muffler|WRP Grounding Kit|RT QuickLift ELITE hood struts|Donnelly Temp/Compass mirror|Coming soon:LazerLite Tonneau cover| |
Yes, we've already had it done. Is 110% better. Feels like new again and is silent.
2005 Nissan Frontier Super Black Crewcab LE 4x4 W/Desert leather interior. (PAID OFF!!) 2005 Nissan Altima 3.5 SE-R Sheer Silver/ Black/Red interior... GONE! You will be missed! 2008 Honda Odyssey EX-L with DVD/NAV. (PAID OFF!!) 04.01.08 triplets killed the Altima SE-R! |
How many miles were on your truck when you had it done? Any hassle at the dealer? I pulled my calipers, looked at the pads and rotors BEFORE finding out about this TSB. Put everything back together and it does not squeak as loud- hopefully it will before I get to the dealer...
We had around 12,000 miles. I had taken it in to the dealer 2 times before complaining about it prior to the TSB release so they had a record of my problem ahead of time. The dealer had no issue in doing it and was very nice about it. From the TSB it appears you get almost a full brake job except for rotors being turned or replaced.
The squeak we had was worse when it was cold or damp out. Good luck!
wonder what they'll sya when I call about mine...I'll hit 45k this month.
i will be hitting 45k on mine this month too. my brakes squeak a lot. i had them checked out and they said the brakes were fine. ill be calling the dealer monday morning.
![]() ![]() 06 LE KC 4X2 Granite VentureShield extended clear bra, X-pel headlight and fog light shields, 3M A pillar and roof bra, Tekstyle Profile tonneau cover,OEM towing kit w/4 & 7 pin harnesses, Carriage Works 4 piece grille, Covercraft seat covers, 3M 35% tint, WeaterTech dark side window deflectors, RedLine Tuning QuickLIFT Elite hood lift, Homelink mod, Asmoil EA air filter, Romik SS Max bars, Nissan iPod interface, PIAA Xtreme white plus headlight bulbs, hardwired V1 radar locator, Dynachrome spring helpers, Gibson SS catback, EC mirror w/temp and compass and a few other bits. |
Well, had the front brakes redone per the TSB. New pads, hardware and they turned my rotors. Total cost- $0.00!
However, they checked my alignment, as I asked for, and found it out. Alignment done as well, cost $80.95 anter 10% discount. I'm glad to have it done, but I complained about a pull after I bought the truck 6 weeks ago. I mentioned this and got the 10%, but I may contact the Service Manager or GM and ask to be reimbursed for the alignment. Do you think that is too picky of me?
