Interchangeable Transmission?
29K views 12 replies 10 participants last post by  RyanD1966
#1 · (Edited)
Would any one be able to help me in deciding if this transmission would fit my 05 frontier V6 4X4? I obviously dont want to spend all this cash if its not on the appropriate item.
Transmission Pathfinder 2008 08 Auto | eBay
#2 ·
The trans from any 05-12 4x4 Pathfinder V6* should bolt right up, any trans from a 2nd gen 4x4 Xtrerra or Frontier V6* will also. The trans from the Titan is also the same as in your Frontier but I'm not sure if they bolt right up.
Why do you need a new trans? Alot of the time they can be rebuilt. Buying used is also risky as you don't know what kind of condition its in.
#3 ·
Okay, thats what I thought I just wanted to double check.
The reason im changing it is because I had the rediator fail and it leaked fluid into the transmission and fried the TCM.
I think the bell housings on the titan transmissions have a diffrent bolt pattern.
#7 ·
Titan trans will NOT work. Case is a different length. Even the gear ratios are different.
Next up, transmission computer. Some of the pathfinders used a gated shifter like the Frontiers, others a different style floor shifter that has a manual mode on a side gate. Computers are expecting one thing and give them the wrong stuff and they usually are not happy.
#10 ·
Once tail housing and bell housing is removed all RE5's are identical dimensions weather a frontier,titan,350Z,Infinity, they do have different gear ratios though, and 4 different valvebodies,and about 25 different TCM's.
#13 ·
Okay, we are all over the place here, maybe a moderator separate these out? We've got 1st and 2nd gen discussions mixed in a hodgepodge that'd do Chef Ramsey proud.
owns 2014 Nissan Frontier Pro4x
