I found this online a few years back and this is something I've had stashed in my toolbox for quite some time now. Every time I work on my truck I reference it. So I thought it would be worth sharing I've added socket sizes to all the ones I can remember/ have removed before. Please feel free to post the ones that are wrong/ missing in this thread if you know it!
Disclaimer:
These numbers were pulled manually from the 2005 Nissan Xterra Service Manual (revision Feb. 2006). There could be errors in translation, typos, mis-reading of the manual, brain farts, etc. Please double check these torque specs with Nissan. I take no responsibility if you use these specs and something falls off. Original Thread I Borrowed the info from
I will add to this over time. If there is anything I am missing or someone sees that is wrong, please let me know, and 'll add it.
Front Suspension:
Swaybar Mounting Brackets: 96 ft-lbs [FSU-5] 19mm
Swaybar Connecting Rod (Both Ends): 62 ft-lbs (Replace After Removal) [FSU-5] 17mm
LCA Bump Stop: 14 ft-lbs [FSU-5]
LCA Cam Bolt: 100 ft-lbs [FSU-5] 19mm
LCA Ball Joint Nut: 70 ft-lbs (Replace After Removal) [FSU-5] 19mm
UCA Mount Bolt: 94 ft-lbs [FSU-5] 19mm
UCA Ball Joint Nut: 58 ft-lbs (Replace Cotter Pin After Removal) [FSU-5] 22mm
Lower Shock Mount: 155 ft-lbs [FSU-5] 19mm
Upper Shock Mount Nuts: 22 ft-lbs (there are 3 nuts) [FSU-5] 14mm
Shock Upper Spring Seat Nut: 30 ft-lbs (Replace After Removal) [FSU-5] 19mm
Wheel Hub Mounting Bolts: 44 ft-lbs (there are 4 bolts) (Replace After Removal) [FAX-5] 17mm
Center Hub Nut: 101 ft-lbs (Replace Cotter Pin After Removal) [FSU-5] 32mm or 1 1/4"
Rear Suspension:
Bump Stop: 14 ft-lbs [RSU-5]
Upper Shock Mount Nut: 33 ft-lbs (Replace After Removal) [RSU-5] 17mm
Lower Shock Mount: 148 ft-lbs [RSU-5] 19mm
Spring Shackle: 77 ft-lbs (Both upper and lower) [RSU-5] 19mm
Front Leaf Spring Mount Bolt: 84 ft-lbs (Replace After Removal) [RSU-5]
Axle U-Bolt Nuts: 53 ft-lbs (Replace After Removal) [RSU-5]
Dynamic Dampener (weight): 14 ft-lbs
Steering:
Outer Tie Rod End Nut: 63 ft-lbs 22mm replace cotter pin
Front Diff (R180):
Diff Mounting Bolts: 135 ft-lbs [FFD-14]
Crossmember Bolts: 96 ft-lbs [FFD-14]
Pinion Nut: 138-216 ft-lbs (Replace After Removal) [FFD-16]
Ring Gear Bolts: 43 ft-lbs [FFD-16]
Carrier Bearing Journal: 69 ft-lbs [FFD-16]
Diff Cover Bolts: 30 ft-lbs [FFD-16]
Rear Diff (C200):
Pinion Nut: 107-238 ft-lbs (Replace After Removal) [RFD-15]
Ring Gear Bolts: 58 ft-lbs [RFD-15]
Carrier Bearing Journal: 69 ft-lbs [RFD-15]
Axle Bearing/Hub Nuts: 49 ft-lbs (there are 4 nuts) [RAX-7]
Diff Cover Bolts: 36 ft-lbs [RFD-15]
Rear Diff (M226 w/o Locker):
Pinion Nut: 220-500 ft-lbs (Replace After Removal) [RFD-50]
Ring Gear Bolts: 133 ft-lbs (Replace After Removal) [RFD-50]
Carrier Bearing Journal: 80 ft-lbs [RFD-50]
Axle Bearing/Hub Nuts: 89 ft-lbs (there are 4 nuts) [RFD-50]
Diff Breather: 31 in-lbs [RFD-50]
Diff Cover Bolts: 31 ft-lbs
Rear Diff (M226 w/ Locker):
Pinion Nut: 220-500 ft-lbs (Replace After Removal) [RFD-123]
Ring Gear Bolts: 135 ft-lbs (Replace After Removal) [RFD-123]
Carrier Bearing Journal: 80 ft-lbs [RFD-123]
Axle Bearing/Hub Nuts: 87 ft-lbs (there are 4 nuts) [RFD-123]
Diff Breather: 31 in-lbs [RFD-123]
Locker Wire Harness: 89 in-lbs [RFD-123]
Diff Cover Bolts: 31 ft-lbs [RFD-123] 14mm
Front Driveshaft:
Flange Nut: 44 ft-lbs (Replace After Removal) [PR-5]
Rear Driveshaft (Model 2S1330):
Flange Nut: 71 ft-lbs (Replace After Removal) [PR-10]
Rear Driveshaft (Model 2S1330-BJ100):
Flange Nut: 41 ft-lbs (Replace After Removal) [PR-11]
Front Brakes:
Slide Pin Bolt: 32 ft-lbs [BR-22]
Torque Member Bolt: 136 ft-lbs [BR-22] 21mm
Union Bolt: 24 ft-lbs [BR-22]
Bleed Valve: 69 in-lbs [BR-22]
Rear Brakes:
Slide Pin Bolt: 19 ft-lbs [BR-28]
Torque Member Bolt: 76 ft-lbs [BR-28]
Brake Line: 19 ft-lbs [BR-28]
Maintenance:
Engine Oil Drain Plug: 25 ft-lbs (Replace Crush Washer)
Transfer Case Fill Plug: 26 ft-lbs (Replace Gasket)
Transfer Case Drain Plug: 26 ft-lbs (Replace Gasket)
Front Differential Fill Plug: 25 ft-lbs (Replace Gasket)
Front Differential Drain Plug: 25 ft-lbs (Replace Gasket)
Rear Differential Fill Plug (C200): 36 ft-lbs (Apply Silicon RTV or Equal)
Rear Differential Drain Plug (C200): 36 ft-lbs (Replace Gasket)
Rear Differential Fill Plug (M226) (with or without Locker): 25 ft-lbs (Apply Silicon RTV or Equal)
Rear Differential Drain Plug (M226) (with or without Locker): 20 ft-lbs (Apply Silicon RTV or Equal)
Manual Transmission Fill Plug: 25 ft-lbs (Replace Gasket)
Manual Transmission Drain Plug: 25 ft-lbs (Replace Gasket)
Automatic Transmission Drain Plug: 25 ft-lbs (Replace Gasket) (both 2wd and 4wd models)
Automatic Transmission Pan Bolts: 70 in-lb (Replace after removal)
Engine:
Spark Plugs: 168 in-lbs
Intake Manifold: Bolts: First Pass: 5 ft-lb Second Pass: 21 ft-lb
Intake Manifold: Studs: 8 ft-lb (If removed from Engine Block)
Intake Manifold: Bolt Pattern: Engine Front: 5, 3, 2, 7
Intake Manifold: Bolt Pattern: Engine Front: 8, 1, 4, 6
Misc:
Wheel Lug Nuts: 98 ft-lbs 21mm
Disclaimer:
Front Suspension:
Rear Suspension:
Steering:
Front Diff (R180):
Rear Diff (C200):
Front Driveshaft:
Front Brakes:
Rear Brakes:
Maintenance:
Engine:
Misc:
