Ok guys, I agree, and disagree...
The offset on my new wheels are what's mostly to blame for my tires rubbing, and I mentioned this in my post... As did I also say "to be safe"
Tire sizes will vary slightly, from manufacturer to manufacturer, and depending on whether you're going with a mud-terrain (M/T), or all-terrain (A/T).
My tires are an All-Terrain tread, both on the old, and the new.
I went from a 31.7" tire, to a 32.6", based on that same info (pinch weld clearance and air-dam clearance), and the new tires rubbed on both areas, even went so much as to grab the front air-dam, while in reverse, and tried to fold them up into the wheel well...
Kinda surprised me that my 6" lift didn't give me enough clearance to run a less-than 1" larger tire!
And while you would expect to see this on the outside shoulder of a wider tire, it did it on the inside shoulders of the tire, too - and the back-spacing is the same on both rims, it's the outside edge that stands wider, overall.
All that, ultimately makes me recant what I listed as an optional tire size, and recommend either a 31-10.5, or a 32-11.5 R15, as his only real options... Because those 285's or larger, are most likely going to rub, regardless of lift height.
Plus he has a 2wd, while our trucks are the PRO-4X 4WD's - which typically sit a little higher in the front, and have a slight bit more clearance than what his does.
So, I stand behind my post, for his safety, on a 2WD fronty - it's ultimately up to him to find and choose what tires he wants, I just want to make sure that I don't give him any advice that'll have him dealing with the same headaches I had.
No disrespect intended to anyone here who has put their .02¢ in, I'm simply adding mine, so we can all be penny-aires, someday
