About a week ago, I replaced my brake pads and rotors on my 2015 SV. I have changed brakes many times in other vehicles, but this was my first time on my Frontier (I bought it used).
Everything went fine except I did drop the caliper on the front left, but it wasn’t a hard drop and the brake hose appears fine. It slid out of where I had it tucked away when I broke loose a caliper bracket.
Bonehead move was not removing the brake fluid cap on the master cylinder. I used a C clamp to push the pistons back in and at some point brake fluid was forced out somewhere, I think through the cap. I didn’t notice brake fluid on the floor until I was done.
After I was done with the pads and rotors, and after I pushed the pedal to seat the pistons, the brake pedal was soft. Not to the floor, but definitely soft.
The next day, I bled all the brake lines to get any air out. I couldn’t see if air came out because I was doing a one-man bleed. The result...brake pedal was still soft.
Today, I bled them again to make sure I didn’t have any air in the lines. Then, to bleed any air in the master cylinder, I ran a tube from the front left brake into the MC. I’m sure y’all know that technic to bleed the MC. I didn’t notice any air bubbles.
I was hoping the brakes would be rock hard, but nope. The pedal is soft.
What the heck? Do I need a new MC? By the way, the brake booster seems fine. If the engine is off, the brake pedal gets very firm after a few pushes.
