I had to change the front brakes pads on my 05 frontier KC 4x4 6 speed the factory pads lasted 99,850 miles. I replace them with Oreilly brand Brakebest ceramic pads. I didn't crack open any bleeder or anything just removed the MC cap compressed the caliper with a clamp installed pads and bolted everything back up. After I was done I pumped the pedal up with the engine off and it pumped up fine. Then I started the truck and the pedal was completely mushy I could press it to floor. The brakes grab about half way down and stop the truck but I can still press on down to the floor. The break pedal before the brake job were awsome you only had to press it down 2" and it was rock solid and you could never press it to the floor.
I went ahead and bleed and flushed the complete braking system with no improvement to the brake pedal.
The only thing I can think of is any internal master cylinder leak.
Any ideas?
Any ideas?
