Turns Over but wont start
2 reading
75K views 20 replies 10 participants last post by  Ynot69
#1 · (Edited)
Yesterday I had a small problem with my truck..it would turn over but not start...I kept at it for less than a minute and it kicked over. Ran my errands never turning it off until I got home...several minutes later I tried it and it started fine.
This morning, I turn the key...It's cranking, but it will not turn over. It has been wet here, but not too cold, nothing lower than 43 F. Battery cables are clean and tight....Help!!!!!
Edit: I am thinking that the battery is not giving enough juice to actually turn the truck over.....reason is that while I am cranking it, the battery gauge keeps going lower and lower...no way to test amps in my driveway though.
#2 ·
Do you have a code yet? Two things come to mind first is the ipdm relays. Thats how mine was acting when they went out. theres 4 I think but I dont remember which one to switch out. Shoul be on here somewhere just do a search. The second is CPS I just had that last month and it was acting like that. Good luck whit this.
#7 ·
Do you hear the fuel pump running when in the acc position with the key?
I had this not long ago, cranked over fine but no start. I listened and didn't hear my pump. I also got no codes. Was about to get mine to the shop when I called my brother for his thoughts.
Kick your gas tank....
Yep kick it a few times, that was my brothers advice to me for the issue. Was pretty skeptical but did so and the I heard the pump and thing fired right up. No problems since.
#8 ·
Called this morning, not covered under recall...contacted Nissan North America spoke to a broken English speaking representative who refused to let me talk to anyone else...however was very adamant that it is not covered via my VIN #.
I also do not hear the fuel pump spin up when I put the key in the ACC position. Kicked the tank several times and it did nothing for me except hurt my toe. Is there a particular area to kick or bang on with a rubber mallet?
#9 ·
Not covered but you aren't sure it's the cause of your problem correct? That's putting the cart before the horse.
#11 ·
I am missing something, where in the posts did it say the idpm was your issue?
#12 ·
It did not, but...the dealer took it off my hands for a nice 2012. Guess that does not really resolve it but they knew about the issue beforehand and still gave me a great deal.
#14 ·
I will post some tomorrow, now all I need to know is what is the largest tires I can put in the rear while leaving the front stock lmaooooooooo j/k
#18 ·
I found this thread doing a google search when my 2011 Frontier had the same issue as the OP. It would crank, but no start. I banged on the bottom of the fuel tank with a 2x4. It worked, the fuel pump activated. My question is; what went wrong and how do I fix the problem. I do not want this to happen again. Vehicle has been extremely reliable. I purchased it new, has about 60,000 miled on it.
#21 ·
Hi sorry can anybody tell me what I'm not doing I have a old one Nissan frontier ran out of gas a few days ago so I put gas started it up and then it died now it just cranks and won't start so I did a scan do me some codes first one is p0300 random cylinder misfire so I took care of that but then my spark plugs and my wires and etc etc and then I have a cold p0420 the Cadillac if you see Bluetooth Bank one I change mode two sensor then I have a p0455 evap emission control system largely I didn't take care of that and p0328 minox sensor I have spark I have fuel pressure give her a basic tune up tomorrow two sensor and she still ain't starting just cranks and won't start please can anybody tell me what am I missing and what I did to do I used to work in a mechanic shop for about four years before
