Tire size aspect ratio question.
2.4K views 7 replies 7 participants last post by  invasion08
#1 ·
Ok Zoom, before you get too upset about my post, just give me a second. I have read a couple things and am not quite sure what is correct. When it comes not metric sizing and the aspect ratio, if I have the same width and aspect ratio of tire, will I always have the same total outer diameter of tire, or is it dependent on the rim size also? For instance, is a 285/75/16 going to have the same total diameter as a 285/75/17 or even 18? I feel like I have read people saying it both ways and am wondering if anyone knows for sure which is correct. Thanks for any information.
Sent from AutoGuide.com App
#2 ·
The aspect ratio is tire width vs sidewall height. If you increase the wheel size, and aspect ratio is the same, then the result is a taller tire. So, using your example, a 285/75r17 would be 1" taller than a 285/75r16.
#5 ·
In general, for every one inch you go up in wheel size, you want to go down about 5% in aspect ratio to maintain the same overall diameter.
#7 ·
Go to toyotires.com - they have specs listed for all their tires
