181 - 200 of 256 Posts
well that didn't work!
If one or more TPMS sensors are bad (usually the sensor battery goes bad), the TPMS relearn procedure won't complete.
Reactions: Zero Six LE
yep, F-this - bought new sensors and still couldn't make the light go away --- removed the instrument cluster, cracked it open on put a small piece of black electrical tape over the light - just as good as disconnecting the bulb (y)(y)(y)
I couldn't take the tape on the clear plastic - I cold still see the light outline and I thought it looked ghetto.
308914
308915
308916
Hopefully your state inspection isn't too thorough, as taping over the light is considered disabling a safety device and will fail inspection if they catch it. Ironically, if there was a problem with the system and the warning light was "on," they can't fail it during inspection as it shows the system is working as it should...if that makes any sense!
it makes sense what you're saying -- but they'll never detect the tape under the clear plastic.
Mine is an 07, I'm not dumping any more money into non-essential component(s) when replacing all 4 control arms up front is on my agenda :(
They don't have to see the tape; they just have to turn the key to the "on" position and see that the TPMS warning light is not illuminated to fail it.
Reading here and watching videos... Some people have trouble with Brand New Sensors. Something Important to Know, If you short the TPMS connector to Ground (6x) and you see the Low Air Pressure light start Flashing Pay Attention to how Long it Flashes! If it only flashes for 1 Minute, It Is NOT In the Relearn Mode! I switched wheels and installed new sensors. I tried to reset/relearn a Dozen Times. Here’s how I solved mine. If you look on eBay there’s TPMS reset tools for $10. I had one I’d used on a C6 Corvette.
1. Set tire air pressures like the OP said!
2. Turning the ignition on the Low Air should start flashing.
3. Use the TPMS reset sensor to Wake Up the Sensors, LF, RF, RR and LR
4. The Low Air Pressure indicator Should still be flashing TURN THE IGNITION SWITCH OFF.
5. Turning the ignition switch back ON, the Low Air indicator SHOULD BE SOLID. (This is where most instructions fail). To Get The System Into Relearn The Low Air Pressure Should be Solid! (The second try is let the Low Air Indicator Flash for its 1 minute after it turns SOLID then Ground out the TPMS reset Wire 6x (with the engine Running)!
6. Ground tap the TPMS Reset to Ground 6x. Watch for the Low Air Pressure Indicator To START FLASHING.
7. Drive the truck. You’ll know it’s in the Relearn Mode if the Low Air indicator Flash’s Longer than 1 minute. The indicator Should Flash for several minutes! One the Low Air indicator goes out, it will come back ON.
8. Pump the tires to the Correct air pressure.
I’m telling you I fought this for a couple of days before I figured out I Was Not In The Relearn Mode! If you have NEW Sensors I think you need to Wake Them Up with one of the TPMS reset tools. (Or try a Magnet?)
I’ve taught Maintenance Technicians for years 3 very important Rules! 1. Never Give UP! 2. Never be intimidated! 3. You haven Lost the Battle Until You Give Up!
Many cheap USB chargers generate enough RF interference to cause TPMS system warnings to flash. If you have a phone or other device plugged into a cheap USB charger and the TPMS warning flashes, pull the plug(s) from the USB charger. If the flashing stops, throw away the USB unit and get some better ones from the web. Google "usb charger interference with tpms" and you'll be amazed.
I bought a five dollar tire pressure gauge and put it in the glovebox ... old school still rules !!! :) LOL
Yes, a lot of TPMS sensors are in "sleep" mode when you purchase them and need to be taken out of that mode using a trigger tool before they are ID registered to the BCM. Magnets usually prevent the signal transmission and is a method that is used in some Ford vehicles during their registration process. Years ago, I purchased the same Kent-Moore tool that Nissan uses for $65. These days, there are versions of the same tool that work just as well available for around $10-15, so it's a cheap investment for those that want to register their own TPMS sensors or wake them. The procedure is also a lot easier with a trigger tool than adjusting all of the tire pressures to do the register process and then having to re-inflate them.
Do you have any links or part numbers for the tools you mentioned?
Happy Thanksgiving. I have what may be a stupid question. I have a 2016 Frontier and I can't find the connector/wire that you ground out to put the truck in tpms learning mode. Did they eliminate those in the 2016 model and newer? If so, then is it required that I use an obd2 tool to re-program my truck? I want to swap summer/winter wheels and have factory tpms sensors installed in both (winter wheel sensors are new). Thanks for any help.
If they eliminated it, which I don't believe they did, then you would have to use a scan tool that has TPMS capabilities to do so. The TPMS diagnostic connector is on the same harness lead as the OBD II diagnostic connector, but the connector is on the right side, under the driver's side of the dash. Follow the harness from the OBD II connector back about 12-14 inches. If it's never been used, there should be a white, 2-pin connector that is wrapped to a larger harness using electrical tape. Undo the electrical tape to pull out the harness connector to where you can access it.
I found it after your advice, thanks! It's way over on the harness closer to the center of the truck. All the previous ones I'd seen in videos had it right next to the OBD2 connector, so I was looking in the wrong spot. Still need to swap wheels and reset it all (fingers crossed it all works). Thanks again.
the light resets itself automatically when you inflate the tires to the proper pressure. i don't understand this thread?
the tire shop can also reset it for you for free if replacing to new sensors or something like that.
