Hello!
Sorry if I have put this in the wrong place.
I'm looking for a little bit of help as this is my first frontier.
I recently purchased an 09 frontier with the 4.0l. It has a periodic cyl 6 misfire code that comes up. Misfire counter ticks up other than some vibration at idle.it doesn't seem too bad. Although the fuel economy is pretty bad. I replaced the coil pack and plug and low and behold the code came back.
Unplugging the coil or the fuel injector produce a hard miss. Can definitely tell the difference when either is not working.
I am wondering is anyone has had a similar problem and maybe could shed some light on this. Cam sensor? Crank sensor?
Doesn't stick me as a module issue, but I'm pretty new to this motor.
