Clicking when starting? (good starter, battery and alternator)
1 reading
8.8K views 14 replies 9 participants last post by  308567
#1 ·
I thought I had a bad starter as I would get clicking sounds when I tried to start. It would turn over on occasion and go back to giving me problems. I had triple A come out and tell me my alternator is good and battery cranking amps were a little low from my truck sitting a few weeks but it’s a newer battery and there were enough CCA that it shouldn’t be a problem starting my truck. I was told it was the starter so I went and bought one and installed it. Went to turn the key and got clicking sounds again. I went to advanced auto and they tested my battery and old starter and said both were good and that I most likely didn’t need to buy a new starter. My head is spinning right now I’m just trying to get my truck running so any help would be appreciated. I’m sorry for being all over the place in my post. Someone mentioned possibly a starter relay so I can look into that.
Has anyone ever experienced this before? Good starter, battery and alternator and have clicking when starting and not turn over? Any suggestions would be really helpful!
#7 ·
Welcome to Club Frontier!! Sorry to hear about your Starting Issues....
First & Foremost, what year is your truck? Automatic Or Manual Transmission? This is important to determine what feedback to give you regarding your Starting Issues...
2nd... Have you checked your battery wires? No loose connections at the battery terminal or loose connection at the Negative Ground wire to the fender/frame? if you have a loose connection at the battery terminal try adding a battery post shim cap to tighten up the connection at the battery terminals. Hopefully it's just a loose battery terminal that's causing all your issues....
Get back to us with the year of your truck and whether it's manual transmission or automatic...
#11 ·
You need to check the terminals at both ends of each battery cable. My initial thought was the ground cable has a bad connection, either at the battery or the block. But there is one cable issue that is hard to find and is often overlooked and that is corrosion where the wire is connected to the battery end terminal itself, both pos and neg. This is covered over with insulation on molded factory cables so you really can't see it. Best fix for this is the terminals where the wires go into a hole and are clamped down with an allen screw. They run about $15+ per terminal, money well spent.
One way to detect this is to remove the cable from the battery, hold it up near your good ear and then bend the cable at the terminal and listen for a sort of crunching sound. Do this with both cables. This usually only occurs at the battery terminal end because at the other end, you can see the wires going into the barrel of that terminal.
Also make sure the ignition wire to the starter is getting a solid connection. Most are screw down but sometimes the spade type are used and they can have issues.
