I hate to be the first one but what do you guys think is the biggest size tire that will fit the 2022?
Both SV and Pro4x.
Both SV and Pro4x.
It will rub and spacers will make it worse. I have 1.5" spacers and a 4" lift and it rubbed. Had to remove the mud flaps and trim down the area. Read through the thread for more details.Hey,
Just ordered a new 2022 Pro4X, looking to upgrade tires before putting in miles. Was wondering specifically is 285/70/17s would fit without any mods? And/or if 1-2” wheel spacers may help?
It will fit if you remove the Valance and mudflaps.Hey,
That’s so badass I love the gray wheels to match the accents of the truck. And the tires are nice and fat, fit the wheel wells well.285-70R17 on a SV with no lift. Just the front valance removed. Barely rubs at full lock when suspension is compressed. I bet you a Pro4X would not rub at all with that size tires. View attachment 337752
what kind of wheels are those if you don’t mind me asking?285-70R17 on a SV with no lift. Just the front valance removed. Barely rubs at full lock when suspension is compressed. I bet you a Pro4X would not rub at all with that size tires. View attachment 337752
Level 8 is a good brand. I’m looking at their MK6 wheels for my S 4x2.Hey folks, first post here and figured since this seems to be the popular tire thread I'll ask here. After 15 years with a 2015 Frontier I am in a nice 22 SV Crew Cab 4x4. Never done any wheel shopping for trucks before. What are the reliable and highly rated wheels I should look at? I see a lot of Black Rhinos in posts, any other names?
Respectfully,
Catalin
def. a factor, running mine just fineWell folks.... I've learnt the hard way... 285-70/17 do not fit. I have 17x8.5" wheels with 0 offset which is a factor for sure... But I don't think they'd fit anyways. MAYBE on stock wheels?
Lift is on the way (thankfully), and the heat gun and zip disc will be coming out.
Oops.
Yes, I’m stock dimensions. I might be talking to soon here but I believe 10mm offset is the most you can have and not rub on “33”He's got 0 offset wheels that are 8.5" wide. Are you at a stock offset & width?
That makes a big difference!
Heck I got a 4" lift with 1.5" spacers that equate to about -3 offset, with factory width wheels and I still rubbed.
You're probably right!Yes, I’m stock dimensions. I might be talking to soon here but I believe 10mm offset is the most you can have and not run on “33”
Oops.
From what I can see, a little creativity with a heat gun and a grinder should work.... But it will be tight. Once the lift is on it will be that much better. I had my shop put them on and I couldn't even leave.... Had to go back to factory.So this is exact setup I want. I thought it was known it would fit but would rub and would need plastic trimming. Can you not just trim and have it work? Lrod had to trim and he’s on -3 offset due to spacers and he’s on a lift. So why wouldn’t a 0 offset fit without spacers. 275 would fix this problem right. Should I stick to 275 and not 285
lrod has the factory wheels which are 7.5" wide.
def. a factor, running mine just fine View attachment 343885[/QUO
Would you mind enlightening me on your trim/heat molding job? Were you having issues in the same areas I've circle d? I'm not too worried about behind the wheel, but that little corner in front has me a little worried. Once lifted it will clear when flat... But I'm concerned about turning when compressed on either side.He's got 0 offset wheels that are 8.5" wide. Are you at a stock offset & width?
The only trimming that was necessary was on that back side. They grinded the area after removing the mud flap. I had zero issues with the front that has you worried!View attachment 343892 View attachment 343894
Thanks a bunch!
Just a grinder? No heat moulding?The only trimming that was necessary was on that back side. They grinded the area after removing the mud flap. I had zero issues with the front that has you worried!
Here:
View attachment 343896 View attachment 343897
That's all grinding. No heat!Just a grinder? No heat moulding?
Have you been playing in the bush at all? If so, any rub up front?
