To crush or not to crush?
5.6K views 24 replies 23 participants last post by  Jazz_Hands_Frontier
#1 ·
Out of curiosity, how many of you throw a new crush washer on when you change the oil? I've only done one oil change on my 2012 thus far but I think I just re-used the one that was on the drain plug... I've never used them on any other vehicle I've owned but just curious what people's opinions are.
#2 ·
I change mine every time. They are cheap, sometimes my dealer just gives them to me if I ask for them. Last time I got a pack pretty cheap on Amazon. In all honesty though, years ago I rarely changed them and I never had a problem with them leaking or not sealing. I change them now because it is cheap and easy and a lot of people say I should.
#8 ·
I've actually had undue hardship in finding replacement washers, the last 2 attempts at getting bulk amounts (like 20 ish, both times) gave me washers that were probably for the 4 banger. Different brands, different sellers, just bad luck on amazon..., as both bags ended up having washers way too large (different sizes though?). My guess is I can use them for differentials or something.
I have not yet changed it out due to this. That being said the original is still going strong "without leaks/seepage" Knock on wood, or steel, plastic.... whatever. I've only ever used a simple 3/8 ratchet to tighten it.
#9 ·
My dealer has given me bags of them, I have never changed one and never had as much as a damp spot. I have 6 cars that I maintain and three motorcycles, none get them changed. Honestly I don’t know why I don’t do it as I already have them here in bulk and give it an occasional thought. I buy 12 Nissan filters at a time so that’s why they toss a bag in.
Do what makes you comfortable.
Reactions: RamTest and domper
#16 ·
I absolutely support those who do change it, I’m just stating on my 2010 Frontier with 128,000 at trade in it had 43 oil changes since I bought it new and it was the same washer for 7 years and never a speck of oil got past it. My next oil change is due in 1300 miles and I just might use one of the dozens I have in the garage. The current truck has used the original for 2-1/2 years already.
Im sure not tightening it until you destroy the threads matters too.
#17 ·
I change mine every time. When I got my 2nd gen Xterra in 2016 I re-used the washer the first time I changed the oil in it, and the drain plug leaked. Ever since then, I have changed the washer at every oil change. They're cheap.
I usually order my Nissan filters on Amazon in bulk, and several times I've gotten them they have included the washers with them, otherwise I just get a bulk pack of the Dorman washers.
#19 ·
Over 12 years, 170Kish miles and doing every oil change myself (4-5K miles OCI), I only changed the crush washer one time. That was at 90K miles, and only because I was taking care of a lot of other regular maintenance items and figured I would replace the oil plug too. Never had any leaks or even a seep, always dry as a bone.
There is nothing wrong with changing it every time, but it is not necessary if you ask me!
#24 ·
I've reused the same drain plug washer for 15 years on many different vehicles and never had a problem. Don't over tighten it and you'll be good.
  • Helpful
Reactions: RamTest
