Radio Removal for 01-04 I think
1 reading
6.7K views 4 replies 3 participants last post by  ochsbeatdown
#1 · (Edited)
Radio Removal for 02-04
Since the sticky is long and doesn't have any pictures here is my shot. I think it would be similar for the 6cyl except you pop out the part around the shifter. I managed to take pictures of about everything except connectors on the back. I did it on my 2004 XE auto.
1. Disconnect the battery.
2. Pull up the bottom tray I pulled it up with my fingers not prying to keep the plastic looking good.
3. Then there are 2 screws once the bottom piece is removed that have to be taken out.
4. Then remove the screws right above the head unit.
5. Once they are removed you can pull off the front plate that includes the airvents, power outlet, airbag lock and light. Be carefull since the connectors catch some in the holes that the wires go through. Also there is some foam to seal of the vents and might come loose and mine the glue was sticky so I just restuck it around.
6. I just put the plate off to the side. I did not undo all the conectors.
7. Then there are 2 screws on each side of the head unit that need to be taken out. Use care when taking out the screws it will fall off the tabs and drop slightly.
8.Then it will slide out. The antenna connection on mine was the standard one. To get the connectors out the back you have to depress the tabs and pull the connector out at the same time. It takes a little effort but it will come out.
I hope this helps since I have already been helped out multiple times on the forum.
#2 ·
good stuff, a bit different on the 5spd and regular single din deck....wish i had any type of guide with pics when i did it lol, i couldnt figure out that god damn wiring harness! lol
#3 ·
I just looked it up some and noticed like all the 01's have a different dash it looks like.
So are all 5spd's different from the auto for 02-04?
I thought they were similar since the sticky had all of them in it. Wasn't sure though so I put the I think in.
Thanks,
Brian
#4 ·
Thanks,
Brian
yeah, manny trannies you gotta pull that center section (between the seats, and in front of the cup holders) out and around the shifter. otherwise, tis teh same.
#5 ·
i didnt have to touch my center console at all, its not attached to anything...i guess 01 is completley different than 02 lol and whatnot...ill put up a pic of mine......bad pics notice the center console not attached at all...and see that black trim around the stereo? thats all i had to take off..
