If your car has an oil light, the light should be ON when the ignition is on and the engine is NOT running.
The oil light should transition to OFF as the engine starts up.
It is important that this work IN CASE you run out of oil.
I do not think many people pay attention to this.
I just finished fixing mine, the light was flickering, and then eventually never came on at all at startup.
It ended up being the oil pressure sensor switch - each fix.
Regards,
Jody
Regards,
Jody
