Is there a test that can be done to check if your condenser is fully functional ?
2000 Nissan Frontier, 2wd, 4cyl.
A 13F drop is TERRIBLE !!!!What temperature difference should I be getting AT IDLE between ambient and vent-temperature. I am getting 13F now. It was 20F before the Nissan Dealer just now replaced the compressor. (They made it worse.) For example, two days ago, ambient was 88F and vent was 75F AT IDLE (with the 'new' compressor).
I did replace the fan-clutch today. It did not fix the problem. But, I do appreciate everyone's help on the how's of getting the clutch replaced.That's the EXACT fan clutch #2570 that I have in both my Frontiers. Pretty straightforward R&R like in the video. "Walking" the fan/fan clutch out is a little tricky, but you'll be able to squeeze it out.
To me, the toughest part is getting the 10mm wrench in there to loosen/tighten the four nuts that hold the fan/fan clutch to the engine without cutting my hands - so wear gloves. I did make an extra-long wrench and ground the box head smaller for easier access. I have used blue Loctite in the past on the four studs when remounting the fan/fan clutch to the engine but I don't recommend this anymore as it makes removal and install of the fan/fan clutch to the engine tougher, as the nuts won't just spin off.
Look online, one way to diagnose a faulty fan clutch using a section of rolled-up newspaper, an inner roll from a paper towel roll, etc. But be careful doing this - negligence of the spinning fan can be dangerous, do at your own risk.
A decent AC mechanic would've also tested the fan clutch when in for repair....
Copied from earlier:
So new evaporator and compressor within the last month. My thoughts:
(1) I wonder if the expansion valve was replaced along with the new evaporator.
(2) Since Nissan dealer said compressor was bad and replaced it, then the AC performance was so poor, I wonder if the compressor was really bad after all. Anyway, the dealer NEVER should've released the truck to you had they been competent, with that AC performance so poor.
(3) Did dealer say the compressor was bad because of a seal or body leak, or were the pressures way off? Maybe they didn't even say, likely they were - in hindsight - guessing with your money. If the compressor was actually making noise or seized, then ABSOLUTELY the condenser and drier should've been replaced.
(4) Did the shop that replaced the evaporator or dealer even replace the drier when they did their "repairs" ?
(5) Both shops "surely" had AC machines to automatically add correct amount of R134a by weight, but wonder if either or both shops made a mistake on adding refrigeration oil (that's typically an edjamacated guess though).
