61 - 80 of 193 Posts
Discussion starter · #62 ·
Alright guys I pulled the trigger today on the connectors needed. Final price will be determined soon and tested results of the wiring will be posted soon as I have a forum member in the process of the swap who I converted the harness for, but I have no doubts that my wiring is 100% correct. Stay tuned!
Discussion starter · #63 ·
The guy I have been corresponding with on the swap has about a days worth of work before he's ready to start it up. He works a lot so he's not sure when he will be able to get another day to work on it, hopefully by the end of the week or so. He went with the Uprev NATS removal because of a few reasons like avoiding a tow bill and dealer charges plus the local dealership didn't really seem like they were on the same page as him whenn he talked to them about flashing the ecu. From what I have heard about dealerships is that some of them are mod friendly others are not. I am currently in the market to try and provide a remedy for this problem. As mentioned before I hope to try to provide a in house reflash cheaper and easier than having to tow it to the local dealer.
Here are some pictures he sent me of the engine in place:
As far as the conversion harnesses, they are already being made by me as we speak:
Discussion starter · #65 ·
Ok it looks like this conversion jumper harness will cover all 05-12 Frontiers/Xterras/Pathfinders using a engine harness for 06-12 Titans. If you end up with a 04-05 Titan engine harness I can make the conversion harness for that aplication specifically by special order. 13+ Applications have yet to be determined but I am sure I can accommodate for those years too.
The total price will be $120 each. Now this was higher than I anticipated, but keep in mind I make each of these by hand, and at $120 each there is not much room (profit vs time) for a actual profit to be worth the trouble. There will obviously be a nice discount if there is enough interest to have a group buy.
In any case I will be holding back sales of the conversion harness till I have tried results which will be any day now as the forum member that I converted his harness for is completing the final steps of the swap.
I will also be offering a ECU flash service soon as I have purchased a Nissan consult and should be able to flash the Titan ECUs to work with our vehicles, if this works as it should I should be able to flash them for you so no towing to the dealership for a flash will be required. The jury is still out on whether or not the BCM and keys to our vehicle would need to accompany the ECU when doing so. I will keep everyone updated.
Discussion starter · #66 ·
My Consult arrived in the mail today and it's freakin awesome. My dads Titan for some reason has been slow going into reverse. Normal generic code readers didn't show any codes transmission related, this not only gave me trans specific codes but it also gave me TPS readings and old codes that have come and gone. There is tons more to I am able to do but I wasn't able to mess with it too long. I went ahead and ordered the imobilizer card I need to reprogram keys and ecus. Next thing I need to do is find a ignition cylinder with nats antenna, titan frontier Xterra or pathfinder BCM, ECU and dash harness to make a mock up setup for flashing use.
Discussion starter · #68 ·
More videos to come, he's been driving it for well over 100 miles now. Zero CELs (well he has 2 but we know why, his power steering sensor is broken so that's one code and the other is his fuel level sender that was present before the swap) he's supposed to send me more vids to post up! Harnesses are being assembled as we speak!
Discussion starter · #70 ·
Oh YES! This is good news! I want to do this. How much is it looking like over all? I am down to get a harness just to have when im ready for the swap.
Base price will be $120. I'm planning a group buy so there will be a discount there of course.
0-60 traction control going crazy, spinning hard on a C200 ????
http://youtu.be/iuujx3KuXas
Hey guys I'm Brian the truck in the pics and videos is mine. It's running great and no codes other than an intermittent fuel sender code but I had that before swap. Sinisterfrontier06 did the harness conversion for me and has been a great help with the couple snags that I hit huge thanks goes out to him!!!! Any questions fire away.
So, I've thought about doing this swap, but what aftermarket parts like a supercharger are available? And what amount of power would they be good up to? I'm looking to do this with my 06 se in the future, and keep 4x4 and do a full Titan swap as far as axles and all. My question is, with doing the full swap, what's the mpg on it? And also, would towing bigger things be safer? Like a bigger boat then the frontier could pull with the vq40? Thanks in advance. Hoping someone can give me some insite on these few questions. And all in all, what did it cost for this build?::smile::
As far as aftermarket the vks have everything we do and then some. I don't recall if stillen still makes supercharger kits for them but I believe a smaller company has started making them with rotrex chargers. Mpg wise I get roughly 1 mpg less than I did with v6 in same conditions. (14 to 15 mpg). As far as towing I dunno? Does the v8 pathy have a higher tow capacity than the v6? Guess that'd be a good gauge. Oh and cost think it was roughly 3500 before I sold some of my old stuff.
Engine trans ecu harness done by sinster. Pretty much all he states at beginning of this thread and I'm 4x4 the transfer case from frontier bolts to titan trans and doesn't move u keep your driveshafts
You didn't have to change the radiator? What if I swapped the axles and suspension from the Titan to the frontier? Everything still mount up? I plan on making some decent power with the swap. So I want it to hold up.
Nah I need to quite being lazy and make an update vid or something. I have pacesetter long tubes no cats 2.5 inch exhaust after collectors it ys into one 3 inch pipe then into a delta flow muffler I forget the name basically a Flowmaster knock off then turn down right after the axle.
Thanks it's a lil Loud for my taste the video doesn't really convey it. Bee. Driving it daily ever since without problems
