I don't know. But hey, guessing is fun. Might get your creative thoughts going.
Drain plug?
Have you actually tried a hose? Smaller one?
Any option to disconnect fuel line and then attach your own and pull siphon that way?
If desperate, and If there is a pressure test port, and you trust your pump to live, maybe pump it out by forcing the pump to run
All that being said, I've treated and mixed in old gas. You don't have to get it all unless rusty.
So... there is no drain plug on the tank. That was the first thing I looked for. I've tried a couple siphon hoses, none worked.
As for fuel line disconnect - the lines are on top of the tank which means dropping it, which I don't want to do.
I did however disconnect the fuel line at the fuel rail (sucks that nissan require's a 'special' disconnect tool instead of standard auto shop ones). After this I tried looking for the fuel relay so I could jump the fuel pump to run continuously when I discovered that this truck has no relay and its all part of the ICDM (i think thats what its called).
Then I tried accessing the fuel pump through the OBDII port, but Nissan is stingy on what they release and they did not release the code to allow people to just turn on their fuel pumps through a scanner tool.
After giving up on trying to get the fuel pump jumped, I was able to attach an old garden hose to the fuel line I had already disconnected and so far have been able to get about 5-6 liters out by cycling the truck on/off (via battery switch) to prime it (runs the fuel pump for a few seconds) but the ICDM will only prime the rail once every couple minutes (hences why I'm using my battery switch, because it resets the IPDM and I can keep priming). I got about 5 - 6 liters out this way.
I really don't like this method - turning it on and off - so I tried the siphon again but this time connected it to the fuel line i disconnected from the rail. This also did not work as the little hand ball pump thing can't pull hard enough and just stays stuck. It just doesn't have enough force to pull it through the truck and the fuel pump inside the tank.
Anyway, next thing I am going to try is: i bought a small 12v low pressure fuel pump that connects direct to the battery for $30CDN that I am going to connect it to the fuel line I already disconnected and pump it out that way.
I really just wanted to see if there were any other options out there; mainly what ways to turn on the fuel pump.
