How do I test my fuel pressure?
9.7K views 12 replies 5 participants last post by  doneill127
Have you tested the fuel pressure under load? I had a vehicle once (carbureted, but still valid) that would show proper PSI at idle and revving the engine in the driveway but driving, if you stepped on it the pressure would drop. If you are at 30PSI and the range is supposed to be 45-50 you are low. I'd look for the Nissan spec over a Haynes manual spec though.
