error with burned cd's?
3.3K views 18 replies 15 participants last post by  smokeydadog
#1 · (Edited)
I have the stock cd player in my frontier and with almost any burned cd i put in it the error message comes up.... however i can press fast forward a bunch of times as soon as i put the cd in and it will work maybe every 1 out of 3 times and it will play the whole cd through as many times as i want, it's just getting it first going that is a problem, and i tried using diff cd's, cd burner program, im using just regular cd-r's. i thought this was kinda weird, anyone else have the same problem?
#4 ·
Plays every time
SD_Frontier said:
almost every cd that i have put in my stock (non RF) unit has been a cd-r and they have played every single time.
Same here...
Stock single CD system with no mods, base Windows burning software and it plays every time.
#5 ·
I swear my cd player does not like my taste in music.
with burned cd's it picks and chooses which ones to play.
#6 ·
Short answer - try burning from a different PC and see if that helps. It did for me.
I do know that the hardware - not just the software - can vary how a CD is recorded. One may work fine in one player, but not in another. The ones from my home PC work (mostly) while the ones from my old laptop wouldn't work at all.
#7 ·
i tried using a different program from the 2 i had on my computer and needless to say it works fine now and plays all my cd's.. i just used the itunes cd burner and it converted all my songs to a weird format but it works fine now. thanks for the replies, just glad it was something small since i dont have the money for a new cd player
#9 ·
I've had the exact same thing happen. There seems to be a correlation with my cd player acting up and the outside humidity. I bought my truck last year in June and it was a problem I noticed right away and dealt with all through the summer. It magically fixed itself in about September and I didn't have a problem until June again. My guess is it's humidity because it was plenty hot here in May but it only acted up in June when the nasty humidity came.
#11 ·
all my burned cd's work fine for me. my cd player has never rejected one of my burned cd's.
#13 ·
I had the problem of mine rejecting my cd's. I changed the radio, problem gone!
#15 ·
I can top all that, one day mine refused to play an original...any original but it would play burnt CD's.
The next day it was fine, hasnt done it since.
I just wish it played mp3's...
software, recorder, media can all be factors.
#19 ·
Lon said:
Try writing the CD at a slower speed. I have found that it helps with players that are made to a price and are of questionable quality.
That's a great suggestion. Also, the brand of CD matters as some blanks are very cheaply made. I burn lots of DVDs, and in that case Japan makes the best. The cut-rate discs from Korea, Taiwan, etc. just plain suck. I order Taiyo Yuden brand from www.meritline.com and never burn coasters. Good stuff.
