Diamondback cover
1 reading
14K views 33 replies 6 participants last post by  GreyFox
#1 ·
Just installed my Diamondback cover (and the matched Front Runner rail system). The brackets are a little too short in my opinion (still talking with Diamondback about it), but overall was a good fit and pretty easy install. I was able to do it all myself, though a second person would definitely helped at certain points.
Happy with it so far.
#3 ·
The ones that attach the cover to the bed. In fact the bolts for the bracket were even too short, I ended up having to go buy new, longer ones from Lowe's Depot. Beyond that, the cover install was pretty easy though time-consuming for just me. This is definitely the part where having helping hands would have helped. I attached a pic of the bracket.
Installing the rails was a little tedious, though not particularly difficult. There are 3 separate tracks per-side that you have to attach to the cover and being a perfectionist I had to get them all aligned perfectly (which helps with the later steps). Once you get those tracks installed getting the leg brackets installed is a bit tedious as well - a lot of angles to consider depending on how much of a perfectionist you are. They really need to be parallel with the opposite bracket (the track perfection helps here a lot); and they really need to be placed as close to equidistant from the perpendicular of the back of the cab, if that makes sense.
Overall very happy.
HTH
P.S. they give 10% discount to military which helped a lot, in case anyone is turned off by the price and happens to be military. Don't get me wrong, It's still an expensive cover :D
#4 ·
Yeah, those clamps do not look like they have enough "bite" on the side. Maybe they sent you the wrong clamps? From many others, I have heard that DB is very good about making things right when it comes to sending out replacement hardware and customer service. Another reason I'm going with them.
The P4X I'm getting has the utilitrack, and I plan to use the DB clamps for the utilitrack. While I may lose some real estate on the track from the anchoring of the DB, it will be a sturdy anchoring point vs removing the utilitrack and anchoring directly to the bed IMHO.
#11 ·
I am pretty sure you could use either, but since the utilitrack is there, might as well. However, there plastic lip that covers the bedsides hangs pretty low. may require a trim if the clips are not deep enough.
Reactions: GreyFox
#18 ·
You want them tight. As you approach the crush weight of the weather stripping the cover loosens up. I have had over 1000lbs numerous times but the first few were eye openers as the cover was now super loose. I remember my hardware looking like yours, thought the bolts were too long, but its been over 4 years now and no issues. Also, you will probably have to adjust the door gaps every so often. I love the cover, went with silver since I imagined the bed becoming an oven in TX. However, you will need sunglasses and sunscreen if your spend any amount of time near it in the summer.
I get what you are saying about carrying things. It makes sense and I do the same, but with just the head ache rack. I was primarily talking about the tent guys. I would love to out a tent up there and would use it often, but that makes things more fixed in place then I want. I am in both sides of the box often.
Reactions: GreyFox
#20 ·
That's great info Dave, thanks! And good to know.
I live in Austin also. We'll have to measure temps and see! ;)
#26 · (Edited)
So DB originally sent me the longer bolts/clamps to attach the cover to the utilitrack. The bolts and clamp are a bit long and not stable enough to get a good bite down, without having to torque down on the bolts, which in turn tend to cant and start to cross thread /cut into the aluminum clamp. This creates more issues as the more you tighten, the more you cut the bracket, and eventually strip the clamp. :(:mad: Seems this issue has been around for a few years on different model trucks based on my research in various forums.
That being said, DB is aware of the clamping issues with our model truck and are working on a better design. (Anyone in the PA area that is willing to bring there truck over for some research and development I guessing will get a a good deal on a cover if you help them out??)
Until then, DB is shipping out not only four more of the longer utilitrack clamps, but also suggested I temporarily remove the utilitrack and install their regular bed rail clamps, and re-install the utilitrack back on. In essence, the bottom clamp will fit in-between the track and the bottom of the bed rail. The regular clamps supposed to be shorter and provide more bite with less canting/stress that comes with the longer utilitrack clamps. I will post my findings once I tackle this upon receiving the new clamps.
I just wanted to share my experience with DB and their product as I know several people have and will continue this cover. I think the cover is an excellent product and the build quality is great. I was just disappointed that the main installation clamps were the weak points of this major purchase. 🤞
#27 ·
So DB sent me the bedrail clamps which are much more robust. I had to loosen/remove the utilitrack temporarily to mount the lower clamp under the bedrail (Utilitrack comes off easily with a T40). Once the clamp was installed, I tried to remount the utilitrack, only to find out the clearance was a bit tight by about 1/8". So I had to remove the clamps and "modify" them by trimming/filing a section on the bottom of the clamp for better clearance. Once the modifications were done, the utilitrack went back on with no issues. I let DB know my findings for future development/editing of their clamps for our vehicles. Hopefully they take notice as I know others will purchase the DB in the future. Either way, the cover is great, and the clamping system just needs to be tweaked. DB could easily make the bottom clamp 1/4-1/2" shorter and it could be used by owners with or without a utilitrack, and it would eliminate the need to have two different types/sizes of clamps. Just my two cents 😉
#30 ·
Myself as well. Though they seemed not particularly interested. They had the original designer/engineer call me and he honestly seemed more interested in defending himself. But I agree; hopefully they do take all this feedback to heart
#28 ·
That bed looks good in black! I see a lot of concern with the clamps and such. Mine look the same. I have never really liked how the bolts flex when super tight. 3-4 years in with no problems with mine though, loaded to it's max quite a few times. However, check them every few months or after you have load it heavy. Really surprised they say only 5 lbs tension... No way in real world use. You would take a turn or good bump in the road and off it would go. Not a good day in my book.
Reactions: GreyFox
#29 ·
Definitely plan to recheck the clamps once in a while. As far as the bolts flexing, I "think" it is an optical illusion. I think the bolts are straight, but are going in to the threading of the top clamp on an angle?? The bolts are hardened steel and the clamps are aluminum. I would assume the aluminum would give before the steel, but I could be wrong. Either way, glad I have the shorter clamps vs the longer bolt ones. Seems to be more secure and the top clamp they gave me seems to have more "bite" as well. Overall, very pleased with the cover and highly recommend it (y)
#31 ·
I was tempted to just hit the local hardware stores to see if a simple C-clamp (correct size of course) would work as well. I mean they wouldn't have to reinvent the wheel, just get the sizing correct. I mean with how many different size truck bedrails there are, I'm sure some models/sizes could be used for several truck models. Maybe they only have three sizes (S, M , L 🤣) and are just trying to get away with not making too many sizes to avoid manufacturing/storing complexities 🤷‍♂️ Either way, it seems to be holding well now. Maybe the next DB purchaser here could share their clamping experiences as they may get the "updated" 2.0 version?? Still a great cover and I get just as many positive comments on the cover as I do on the truck (y)😉
#32 ·
@GreyFox I just received my cover and was wondering if you know the difference between the regular and utili-track clamps? I like how you installed yours and was thinking of taking that route but I have the utili-track clamps. Do you know if I just grab shorter bolts, if they would work. Just don't know if the clamp design itself is the same.
#34 ·
I had a few minutes this afternoon and figured out that the lower half is def different. Looking back at your pics and the little space between the rail and the top, is def a tight fit.
I'm going to go with the rail clamps for now and get it put on tomorrow. I'm to impatient to wait for a new set of clamps.
Yeah, DB has a different set of clamps for just the bedside mounting. You have to temporarily remove the utilitrack, clamp the the top, and reinstall the utilitrack. When I did mine, the tolerances between the track and the clamps was too tight for me, so I filed/sanded down a notch in the lower clamp to clear the track. Otherwise its very sturdy with the bedside mount clamps compared to the track mount ones (too long of a bolt with too much torque/stress on it IMHO). The guys at DB are great, if you need any parts or info. I'm hoping they tweaked the bedside mount clamps to clear the trucks with the utilitracks?? Glad you like the top. Have someone sit on top of the panels when you adjust the locking bolts as this will "squish" the seal down further and give you a better seal ;)
#33 ·
