Guys, I have been following this board for a while and most of the time there is a topic or thread that answers my issue however this time I am stumped.
My 2000 SE CC has 297,000 miles on it and it still runs like a champ however lately it is losing coolant like crazy to the tune of a gallon every 60 miles or so.
There are no drips that it leaves when parked other than some oil but i am pretty sure it is the drivers side valve cover.
I got so frustrated that today I started the timing belt project and then decided to pull the intake manifold off to see what it looks like.
The spark plugs are all perfect, nice and tan with no discoloration of any sort. There is not any smell of antifreeze that comes from the exhaust when it runs. The oil is dark but there isn't any indication that there is antifreeze in the oil and there isn't any of the oil gunk floating in the coolant system.
The engine valley under the intake is a complete mess. It is full of gunk. I am wondering if that is where the antifreeze was going. One of the intake manifold bolts was covered in antifreeze residue/rust.
The intake manifld gaskets look like they were leaking a bit because the gasket surfaces were not completely shiny all over. They had some dark areas and one or two cylinders even had some of the gunk on them.
Is it possible all of this is because of bad intake manifold gaskets? I really don't want to pull the heads since i need to have this up and running to get to work on monday and the machine shop won't have them machined in time. The other issue I am having with the diassembly is getting the bolts out for the camshaft pulleys. i cant get them to budge aso even if I wanted to I could take the heads off because the pulleys are still on there.
I know the easy answer is
"Pull the heads"
but in this case it isn't the easy way out for me so any ideas or experiences would be greatly appreciated.
Sorry for the long post but I had a lot of info.
Thanks Paul
"Pull the heads"
Thanks Paul
