you could disconnect the battery for ~10 minutes, or do the reset ecu trick (see below)...I think there must be a fuse for the ECU somewhere, as well.
do you have a pep boys or autozone (outside of CA) that can read the code for you? Not a bad idea to get what turned it on, even if it's nothing...they can reset the code for you also.
Obviously, if this is a reoccuring problem, the CEL will come right back on.
EDIT - here's a quote from another posting on this forum:
"ECU Resetting Procedure
When counting, count in your head or use a stop watch.
1. Turn ignition to ON, count to 3.
2. Depress/Release accelerator pedal 5 times ... hard and fast
3. Count to 10 and fully DEPRESS pedal.
4. Count to 12 (SES should be blinking), RELEASE pedal.
5. Count to 10, DEPRESS pedal.
6. Count to 10, RELEASE pedal.
7. Turn off ignition, then start engine, DONE!"
I've done this and it works (just heed the timing in between)...however, I wish I hadn't as I swear it has gotten worse mileage than it did [although most claim to have gotten opposite effect; weird]
