First of all, no "search" mention. I did alot, since december, here and all over google. Also used FSM. And nothing could help me.
I'm having a spongy brake pedal on my truck since december. Was on the road to family for Holliday. The truck had a kind of bug: brakes applied suddenly and briefly 5 or 6 times by themselfs. 4-5 minutes between each event. Never did it again. Clean road, no dust/sand, no ice or snow. But first half of brake pedal travel became soft, without real brake power.
When reaching destination, I bled my brake system. Little to nothing better. Searched here and over google. Tested brake booster like FSM tells. Everything is ok. With engine off, and pedal depressed few time (no boost) a medium/hard pressure on pedal doesn't result in depress. So no suspition of internal/seal leak into bkake master cylinder.
Removed all 4 caliper, tested all slider and pistons. No rust (lubricate 2x year) and nothing sized.
Find out that our trucks are hard to bleed and need several bleeding to have a good result. So bought 2 quarts of DOT3 and bleed my brake system like FSM tells.
Still same result.
Any idea?
42500km 2011 CC long bed, 4x4
Still same result.
Any idea?
