Nissan CPO is an extended warranty. 100K/7-yr from orig new car in-service date. Typical extended warranty coverage. Repairs must be done by Nissan.
$600 to get a receipt for buying the car ??
Time to look at another brand, especially with no dealer network nearby.
It's always good to check out what's NOT covered by these warranties:
WHAT IS NOT COVERED UNDER YOUR NISSAN CERTIFIED OR CERTIFIED SELECT WARRANTY:
1. Any component not listed in the “WHAT IS COVERED” section of this Limited Warranty.
2. Any and all High Voltage Electric Battery (EB) cells/modules and sensors.
3. Suspension, steering system, brake system, and/or regenerative braking systems, and air conditioning system, including refrigerant.
4. Paint, carpet, glass, upholstery, soft trim, weatherstripping, squeaks,rattles, water leaks, wind noise, moldings, bright metal, infotainment system, air bags and any related sensors and modules, 12 volt battery and cables, belts and hoses, tires, wheels, immobilizer key. Headlight systems including, but not limited to: High Intensity Discharge, Adaptive Front Lighting, Daytime Running Light, Head lamp/Tail lamp assemblies, Center high-mounted stop lamp assembly and their lenses, bulbs/LEDs.
5. Maintenance service expenses specified in your Owner’s Manual such as, but not limited to: engine tune-up, wheel balance and alignment, spark plug and wire replacement/adjustment, timing belt replacement, fluid
and lubricant replacement/replenishment, wiper blade replacement, headlight aiming, filter replacement, brake pad and shoe replacement, and air conditioning refrigerant replacement/replenishment.
6. Any repairs related to loss of performance caused by normal wear and tear unless an actual MECHANICAL BREAKDOWN occurs.
7. Any failure due to damage resulting from: accident, re, theft, flood, water damage (including water ingestion), freezing, alteration or modification, improper repair, improper installation of any Nissan-approved accessory, vandalism, explosion, natural disaster, acts of God, environmental condition (including fallout or acid rain), physical damage, or any outside influences.
8. Any failure resulting from: lack of scheduled maintenance including but not limited to sludge build-up as specified in your Vehicle Owner’s Manual/Maintenance Logbook; misuse (proper use is outlined in your Vehicle Owner’s Manual); use of improper or contaminated fuels, fluids or lubricants; failure to maintain proper fluid, coolant or lubricant levels;
use of inferior or modified parts; modification of the vehicle beyond the original factory specifications, including installation of non-Nissan approved accessories or components; pulling a trailer or other vehicle that exceeds Nissan’s recommendations or exceeds the maximum Gross Vehicle Weight (GVW) of the vehicle; corrosion or any damage or failure due to rust or corrosion, and damage or failure due to or caused by racing or other competition; service adjustments not usually associated with the replacement of parts; any vehicle with an inoperative or altered odometer so that the actual mileage of the vehicle cannot be determined; any vehicle used for commercial use (such as a taxi or limousine service); any expense that is covered by other existing warranties, including but not limited to the original New Vehicle Limited Warranty provided with your vehicle, as well as parts warranties, other warranties or other agreements; or any repair or replacement that has not been authorized by Nissan or in which the information provided to Nissan cannot be verified as accurate or is found to be deceptive.
9. This Limited Warranty does not apply and is rendered void if any vehicle has ever been issued a “salvage” or similar title under any state’s law, or has ever been deemed a “total loss” or equivalent by any insurance company, such as by cash payment of a claim in lieu of repairs because of a determination that the cost of repairs exceeds the actual cash value of the vehicle.
9. Any part or repair that may be covered by the original manufacturer’s Limited Warranty, Warranty Extensions, Recalls or Campaigns.
