2010 370z TT
983 views 32 replies 6 participants last post by  sirnixalot
#1 ·
Welcome to my imitation GTR thread.
I got this new to me 370z about 2 years ago and it's been a long road.
328262
How it started
328263
How it's going.
To digress here is the current mod list.
Drivetrain
BTWTuning Ecutek flex fuel remote tune
Built engine - Wiseco 9:1 96mm pistons, Eagle H beam rods, ARP L19 head studs and 2000 main studs, JWT C2 exhaust cams & springs
BTWTuning GTR turbo adapter kit with twin GTX2871R's
Custom (Me) intercooler kit with Vibrant 25x11.8x3.5 core
Custom (Me) 3" downpipes & 4" exhaust
Custom (Me) oil catch can/coolant reservoir
Custom (Me) power steering reservoir
Ported upper and lower intake manifolds
B&M shifter
Zspeed CMAK
OS Giken Street Master twin plate clutch
Z1 Motorsports engine mounts & Transmission mounts
Nismo 1.5 way rear diff
Z1 Motorsports rear diff cover
Whiteline rear diff bushings
Fuel system
CJMotorsports Twin pump fuel system Walbro 535LPH primary, 485LPH secondary
ID1300X injectors
Suspension & Brakes
Z1 Motorsports front UCA
Z1 Motorsports rear LCA & Toe rods
Fortune Auto 500 coilovers 10k/8k
Voodoo13 solid rear subframe mounts
Custom (Me) line lock kit
Power Stop track day pads all around
Street trim: Work T5R 2 piece wheels in 19x10 20mm front, 19x12 20mm rear wrapped in Cooper Zeon 285/35R19 front & 325/30R19 rear
Drag trim: OEM 18x4 spare wheels up front, Forgestar 17x9.5 50mm with 25mm spacers rear wrapped in M&H 28" front runners & 28x10 M&H bias ply slicks
Interior
Bride Vios 3 drivers seat
Bride Eurostar passenger seat (not arrived yet)
Ebay stainless steel 1lb shift knob
Gutted trunk
Innovate EFC-1 fuel pressure/fuel temperature/ethanol content/wideband gauge
Innovate Oil pressure/temperature gauge
Innovate Boost/RPM gauge
Exterior
Ebay front lip
Duckbill rear spoiler
328265
Here's how it looks in street trim
328266
Here is drag trim
328264
So far on the stock motor and stock GTR turbos on E85 at around 600wph I have run a personal best of 7.33 @ 95mph in the 1/8th with a 1.69 60ft. I need to get some BC ER double adjustable coilovers so I can control the car better down the strip.
We don't have a dyno on island so I've been using virtual dyno to quantify things.
328271
E85 max effort tune on stock motor
328272
93 octane pump gas tune
The car is a fucking riot on the street and I cannot wait to get it running again. Next time out with the GTX2871R's I will be keeping the same ~500whp level for the low end map, with the 9:1 compression though I can make some more power on pump for sure, I will defer to Husam @ BTWTuning for that. E85 map the main focus is to keep TQ at or below 600 to keep the head gaskets happy. To run big power on these you need to go to Mazworx and I just don't have the appetite for that at the moment.
Lately I have been fighting an issue where the VVEL on the passenger side does not want to work so I am waiting on some new to me cylinder heads/vvel assemblies after they get a clean bill of health from the machine shop. I have the motor out at the moment in preparation
Here are a few random pics of where I am currently
328268
328269
328270
#5 ·
Well seeing the VK swap running made me find some ambition for the Z again. Got the motor reassembled and started on the new intercooler & piping.
Plan is to have everything buttoned up after work this coming week and ready to drive next weekend.
#8 · (Edited)
Drove it to work today, no issues at all on the drive. There is a strong scent of fuel coming from the fuel pump hanger, snugged the bolts down some more, if that doesn't fix it I'll need to order a new o-ring for it.
2nd gear 60-70% throttle when the boost comes in the 325's can't keep up lol. I have Cooper Zeon' RS3's on it, figure there was no point in any sticky tire since they would just lose traction at higher limits. There is no tire that's going to keep up with this kinda power on the street anyway.
Once the track opens back up next year we will see if I can finally break into the 6s in the 1/8th.
I had to make sure the line lock worked on Sunday 🤣
#9 ·
Fuel smell appears to be a torn O-ring on the factory feed line connector at the top of the fuel pump hanger, which is now the return. I have some new quick connect fittings and some -6AN that will be replacing it tonight. With the fuel smell gone I MAY be able to take the wife for a drive, I know the car is too loud for her and the fuel smell doesn't help.
#11 · (Edited)
So I’ve been driving it, it’s been behaving for the most part. Got an OEM GTR map sensor in there so I finally know that I’m running 13psi.
It has a horrible horrible exhaust note around 3k rpm so I decided to try a 1/4 wave resonator. It's working perfectly, car still has that VQ rasp but the noise right around 3k rpm has been canceled out and it sounds more GTR'ish.
It worked perfectly
#12 ·
Much has happened. Mainly the head gasket has popped so out comes the VQ........again
I am recouping some money selling off the turbo kit, internals and some of the fuel system.
I refuse to keep doing the same thing expecting a different result so, it's LS time. I found an 84k mile drive train out of a Camaro off ebay to repower the Z. Plans are to get somewhere in the 475-500whp range NA and spray it with another 150 or so at the track.
90% of the swap stuff will be here by August, lots of back order and logistical challenges.
#13 ·
Woah... this is gonna be cool. Just found this thread - gotta go back and read the whole thing. Looks like you've done a lot... (understatement)...
#14 ·
The hits just keep on rolling. Finally got the engine home this week and got it on a stand to find the push rods on cylinder 4 pushed up past the rocker arms. The trunnions failed but luckily the head/valves and pistons are ok.
I have to order some more parts but I did manage to get the crank scraper, oil pump and cam installed. I'll get the rear galley barbell from improved racing installed tonight so I can seal up the bottom end with the sikky oil pan.
Trunnion failure
Pulled the bolt right out of the head, which means helicoil time
Crank scraper and windage tray. Since it's staying N/A I'm trying to do all the little efficiency things to help out.
Ported the ridge out of the throttle body, same as what I did for the one that went on the VK.
No pictures of the cam or oil pump install since that's pretty boring.
#16 ·
Last night I got a few things done. Installed the oil pick up tube & brace, oil pan & filter adapter block, oil gallery barbell and lastly the LH engine mount.
The RH engine mount bracket requires a little grinding/cutting on the AC compressor bracket.
Oil gallery barbell from Improved racing, it doesn't allow the oil to bypass the filter like the stock one does.
Another small Improved Pacing part, oil pick up tube brace. Not sure why even the aftermarket tubes don't use both mounting bolts.
Pretty slick how they designed this adapter block, it bolts from the engine side with copper crush washers and there's no room for the bolts to back out. I still used some blue thread locker though.
The oil pan required one allen head bolt for clearance up front but the stock bolts went back in for the rest of the locations.
Highlighter green is now my favorite color
#17 ·
Confirmed with Sikky that the AC bracket does need trimming so that got the chop!
You can spot the Hawk Motorsports low profile fitting block. Not sure I need it but it makes plumbing up the lines easier since I don't have to cut and weld to the stock thin wall tube.
Sikky 12" long shifter relocation and 8" tall shifter stick. I think most of the weight gain from the LS swap is from this piece, its solid!
My card board aided design shroud. Got the top and bottom edges bent at the machine shop, I'll be bending a 3/4" strip for the sides then figuring out a mounting solution.
#18 ·
I'm sad to see the vq go..... I get it though, it's a much cheaper world going ls. I'm now going to get my box of tissues and sit on the couch...
#19 ·
I am sad as well but It's just not reliable past a certain power level. If I wasn't so greedy and could settle for 600whp/450wtq then it would be fine on the stock VQ37 long block.
I prefer to keep to one manufacturer, a bit of a purist but I refuse to "pioneer" a VK swap and force my self into hours of labor for headers (i hate building headers) and figuring out wiring only to be stuck with Uprev. At the end of the day I couldn't argue with the bolt in, plug and play solutions that the aftermarket has provided for the LS
#20 ·
You had a built engine right? What was the next step to handle the extra power, billet or sleeved block or something? Also, im happy you moved out of the insanity boat, im still there.
#21 ·
Just had a look at mazworx. How much power can that stage 2 block handle?
#24 ·
And that was lifting around 600?
#25 ·
Nah around 900 or so. There’s a thread on the370z by a guy named spooler that’s been really open documenting his built motor trials. Long *** thread but the info is in there
The stock vq37 will do 600whp reliably once torque is kept in check and under 450
#26 ·
Sorry I haven't updated this. I got the LS in for some mock up work.
The new radiator support and tow bar. It's made from 1/4" plate, 1 1/4" and 1" tubing
All of the coolers mocked up and mounted in their new home. I intend to be able to hot lap the car at the 1/8 mile track so it got a 34 row oil cooler, 10 row transmission cooler and a 7 row powersteering cooler. The intake is a modified Sikky tube to get down in the front bumper area.
Shot from above showing the expansion & reservoir tank combo as well as the VTA catch can I made. The radiator itself will have a 0psi cap and the bleed nipple will go to the expansion tank, the other 4an hoses are from the steam ports.
The rear of the expansion tank has a 12an bung that connects to the 3/4" heater hose nipple on the water pump.
Oil cooler plumbed to the thermostat/relocation block
Fuel feed line ran, I had to convert to a dead head setup with the regulator which barely clears in it's original location.
All in all the Sikky kit made it pretty simple, I did have to BFH the top of the transmission tunnel to clear the shifter relocation assembly and 2 spots on the secondary fire wall.
#27 ·
Been a while for updates on this one. I had a customer car on my lift for the past 5 months so my Z had to sleep outside for a while.
I installed the drive shaft so that I could start mocking up the exhaust.
Cheated a bit and used a prefab X pipe from Pypes. It's 409 and not 304 like the rest of the exhaust but it saved so much time.
Finished up the passenger side last night, once I get the last part tacked the real fun starts, the compound cuts I'm going to have to figure out to get the exhaust cut outs to bypass the muffler and exit through the exhaust tips are going to be such a pain.
Lastly I got the clutch slipper lines bent & flared. Mounted it and also plumbed it to the clutch master.
#28 ·
My brother got me some purge plugs for christmas so I tried them out boxing day and finish welded the mid pipe. Ironically I still had to use foil on 2 ends since I only had two 3" plugs.
A view of the cutting and BFH'ing required for the sikky swap kit and a TR6060 manual transmission. The cut at the top of the transmission tunnel was needed to clear the larger bell housing, I have a template to cut some caps for the holes. The secondary fire walls need some massaging for the heads and the OEM coil pack's & brackets.
One of the rocker arm mounting points got stripped out when whatever went down, went down. I did re-tap for a helicoil but I managed to **** that up and didn't get the 2 inserts aligned properly. The insert at the bottom of the hole caught on the valve spring compressor bolt, so now I have to hope I can EZ out the helicoils.
Comparing the new BTR dual springs & Ti retainers to the unknown beehive springs and steel retainers. I think the old stuff was from Howard since it had a cam and push rods from them.
I decided to remove the other cylinder head and continue on changing the valve springs. The BTR shaft rocker conversion and Summit HDR push rods went in with a new OEM head gasket. There's a million reviews for each style but after seeing the bronze bushings I pressed out worn and shot to ****, I am glad the BTR kit uses needle bearings.
Tools wise I used the Trick flow valve spring compressor (p/n 90307) and Summit trunnion bearing installation kit (p/n SME-906011), I know you can do this with sockets but having the stop built into the tool so you don't press the bushing too far in made this so easy.
Wiring specialties wired up a 4 pin alternator connector even though I specified everything was from a 2011 Camaro. Waiting on their reply as to my options for converting to a 2 pin, if it ends up a pain in the *** I'll just buy a 4 pin regulator/brush holder and swap that out.
#29 ·
Glad to see some progress on this one! Welds look awesome man! How much power are you shooting for? If your old vq setup was stuck around 800, I would assume you want more?
Reactions: sirnixalot
#30 ·
Nice color on those welds too
#31 ·
Thanks! I those were fusion welds, I've never run into an issue doing them to the v band rings and it saves me on material.
For the moment I am just aiming to get it running NA with the mostly stock long block. I think with the electric water pump, intake, long tubes, exhaust, cam & valve train upgrades it should make around 460-470whp. I'll be happy with that for a while so I can actually enjoy it for more than 2 weeks :LOL:
At the track the nitrous will get me around 650, I do plan on getting some drop in pistons and rods and sending the heads to Texas speed for their port work and to mill to bump the compression. Eventual goal is as close to 500whp NA as I can get.
