1 - 20 of 31 Posts
Rogue Admin
2007 LE 4x4 Crew Cab Long Box
I'll get things started, will add links.
Username: Zedbra
Year: 2007
Make: Nissan
Model: Frontier
Trim: LE with leather
Color: Black
Mods:
Interior
* OEM All weather mats
* lots of mud
* 35% front tint with UV protection
Exterior
* Westin Ultimate Bull Bar (from a Toyota originally but I made my own mounting brackets to fit it to the Frontier)
* LED Fogs
* LEER 180 canopy
* 2" DIY body lift
* OEM bug deflector
* OEM trailer hitch with plug relocated to the bumper
* OEM bed divider
* OEM in-channel vent shades front and rear
* CREE LED headlight bulbs
Drivetrain:
*bone stock thus far
Suspension & Tires
* Deaver 2” Rear AAL
* FOX 2" lift coils with Daystar 2" blocks
* SPC Upper Control Arms
* PRG Cam Bolts
* Custome heavy duty 3" lift rear leaf springs
* Rear Radflo 2.0 long travel external reservoir shocks
* Goodyear 285/70/17 MT
* Extended and braided rear brake lines for lotsa flex
* Ride-Rite air bags to help the springs with heavy loads
Armor
* Nissan Nismo Skid Plates - were given to me free from bobblehead
* Trail Gear sliders for a Yota custom fit
Performance
* Volant Cold Air Intake
* Superchips Cortex
* CXJ IMS spacer
Gear and Other
* Variety of tie downs and tools for bush repairs
* 30' 2" Recovery Strap (have a few of these)
* shovel
* Hi-Lift and custom mounts for the utilitrack
In Progress:
* figuring out a custom rear bumper
* CB
Photos:
some trail carnage near the fuel door, on bedside?
Rogue Admin
yes - the stock LE step ripped off and jammed up into the wheel well. Ironically, I was going to take them off that morning but didn't have a deep 12mm socket. I was going to go to the store to buy one when I got called to go wheeling instead. Also more ironic was that I blew off installing my sliders that day to go wheeling.
Rogue Admin
Well, I want a new bumper and I found a local guy today that is interested in making me one. Plus a new front skid.
and thanks - i wanted that pic for a while now.
whats going fellas. just have a quick question....where do you get the rock sliders from??? i went to Trailgear.com and they dont sell anything for nissan there. i also went to Ruggedrocksoffroad.com and i didnt find any rock sliders under the frontier section.....and the very last question is, are these bolt on or cut n weld application???
thanks!
Trail gear does not make their sliders for the Nissan, but they will fit on certain models. They are built for Tacomas, but that doesn't matter..the length is what matters. So the trail gear sliders may say they made for Tacoma's but that doesn't mean they won't fit your Nissan. Many people on this forum are running Trail Gear sliders.
Rogue Admin
thanks!
nat has your answer above. i ordered the trail gear sliders for a 'yota and then cut and welded to fit the way i wanted them. i made my bolt-on, but it wasn't easy because of the long box. I ended up actually welding a few nuts into the frame.
wooo...that seems like alot of work, especially since i dont have a welder or anything to cut metal with. but thanks anyways guys.
......on that note, i found out shrockworks makes a set of rock sliders...but ther run about $400 +.....thats a pretty insane price if you ask me. well i guess im gonna have to think this one over!
Back on the (single/double)track...Zed dude, you have a kick *** build. I really do dig it!
Rogue Admin
if you don't have a welder or cutting tools then this is not a project for you. Everywhere you go will want $400 for pre-fabbed sliders, so the Shrocks are as good of a choice as any.
Thanks man. It gets me where I need to go - up the mountains. Just wish there was a posi for the C200.
^^Nice truck, I like it much. And man do I hear you about some sort of LSD for the C200.
Rogue Admin
Discussion Starter · #14 ·
Finally got around to installing my Ride Rite air bags I have had sitting in the garage half the year. Just in time to add sand bags for winter. I should have installed these years ago, they really smooth out the ride after adding the Deaver AAL lift springs.
And my damaged bumper made it easy to mount the filler
Rogue Admin
Discussion Starter · #16 ·
Well, there is some rust starting to show up on the front Radflo coil-overs - but I must admit that the rust is a lot more minimal than I expected. I just recently started spraying them with Boeshield T-9 to help slow down the process, we'll see that product works.
I had the frame and underbody heavily undercoated when I bought the truck, and I spray the diff and other areas every year with Tremclad (or Rustoleam in the US) to try to keep the rust at bay - you can see in the airbag pics what it looks like after one year.
Rogue Admin
Discussion Starter · #17 · (Edited)
Added some CREE LED light bulbs - bought them off ebay from China. Wanted the Lifetime bulbs, but they wouldn't ship to Canada without using UPS. Anyways, the install was really easy - no cutting, no trimming. I took the intake out to clean it, I think that took the longest of the whole procedure. The light output is excellent for low beams. I'm wondering how long they will last, as I have DRL that are always on, even with just the park lights switched on.
The product box - was well packaged and shipped with no damage.
The bulbs fit in easily enough and the retention ring twisted with no issues and no cutting/trimming
The fan just screws onto the back of the bulb
Went to a pitch black road
DRL
Low beams - I'm 50' from the rope and blocks
Low beams and fogs - fogs have 3000k HID bulbs
The high beams are pretty useless as high beams - unless you hunt squirrels
High beams with my PIAA lights on
Rogue Admin
Discussion Starter · #19 ·
Hey those lights seem pretty cool! I love led lights I even have them in my house! Are you still happy with them?
Ya, so far, so good.
1 - 20 of 31 Posts
