1 - 4 of 4 Posts
Well I had to tow my truck last week. I disconnected my driveshaft (rear) and tied it up. About 400 miles into the tow a passing car told me that I was dragging the drive shaft. Sure enough the rope broke and was dragging on the road and it ground down one of the bolt hole flanges and when I went to reconnect I could only do 3 of the 4 bolts because it was ground down so far. I now have a real bad vibration the faster I go and am sure this is the reason. My question is what is that part called that attaches the rear u-joint and the rear diff? And where can get one??
2004 Frontier crew cab 2wd 2.4 engine
Thanks
Cactus52
Don't drive the truck until parts are replaced. It's very dangerous.
the yoke is attached to the diff , you want the yoke flange
ill double check i may have one in the shed
edit: nope dont have one
1 - 4 of 4 Posts
