1 - 4 of 4 Posts
So i didnt get instructions, but i got everything off enough to put spacer in. My question is the 2 bolts that are on the bottom part, actually in the block, do the need replaced because i got 7 new bolts but not including those canoy replace 5. And i tried putting the spacer on, and the nut wont reach the only two bolts that i couldn't take out. If i need them out how do i do that?
Take a picture of what you are talking about.
I believe you are talking about the two threaded studs that are in the lower intake manifold, not the block. They have an inverted torx on the end of them to help remove them. Yes, they have to be removed as they are not long enough, and then they are replaced with the bolts provided with the spacer.
1 - 4 of 4 Posts
