1 - 20 of 971 Posts
EDIT: The search feature sucks, so if you're looking for some of my other threads here they are
Front Bumper Specs
Projector Build Thread
V-LEDS Dome Lights
OTRATTW Switches
PRO-4X 5 Switch Cluster
Brake MC Brace
TNX Build
New Rigid LEDs
Headlights w/Keyless Entry
Round 3 Projector Build Thread
x_mods Bumpers and Sliders
2WD to 4WD Conversion (Complete)
JeniorNV's thread to end all threads: Suspension Lift Info 05+
How she sits today:
DISCLAIMER:
I'm not sure how my truck got this way, but I know it cost way too much...
I strongly urge anyone who is about to look at this thread to hide your wallets first. You'll thank me later.
Username: x_mods
Vehicle Name: Andromeda, Rommie for short
Year: 2010
Make: Nissan
Model: Frontier CC
Trim: PRO-4X 2WD (Now 4WD)
Color: Night Armor
Packages: Power Leather, Rockford Fosgate, iPod Interface
History: Other than the packages, she was as bare as a
PRO-4X can be.. I have done all of the work listed below myself with the exception
of mounting and balancing the tires, because of the Aluminum rims.
January 2012 ToTM :)
2012 ToTY :)
\/ Mods \/
Interior:
-Black & Orange Wet Okole Seat Covers
-Wheelskins Charcoal Steering Wheel Cover
-DashMat Charcoal Dash Cover
-Black WeatherTech Floor Liners
-BlendMount for Bully Dog GT
-Autometer Phantom II Vacuum Gauge
-V-LEDs Dome Lights/Map Lights
-PRO-4X 5 Switch Cluster
-5 OTRATTW Illuminated Rocker Switches
-Stinger Voltmeter
Exterior:
-OEM Rain Guards
-OEM Trailer Hitch
-OEM Trailer Wiring (4-pin)
-8 OEM Tie Down Cleats
-Smittybilt Hitch Shackle
-Masterlock Hitch Lock (blue)
-Bak Industries BakFlip G2
-Red LED Turn Signal Arrows in Mirrors
-EZDown Tail Gate Shock
-Bosch Icon Wipers
-De-badged
-Full Ceramic Window Tint to ALL Glass
-Orange Digital Camo Tailgate
-808UpFront Custom Front Burger (Orange)
-808UpFront Custom Rear Burger
-Custom Retrofit Tacoma Bakrack Rails
-x_mods Custom 1/3 Bed Rack
-x_mods Custom NMO Antenna Mount
-x_mods Custom Fender Liner Trim
Lighting:
FX-R's are out, TL's are in!
-x_mods Custom TRS Acura TL 3" Bi-X CL Projectors
-x_mods & 808UpFront Collaboration Custom Molded Vacuum Formed Shrouds w/Custom Trim Rings (Orange)
-Morimoto 5Five 55w Blasts
-Philips D2S 85122+ Bulbs
-x_mods Custom Rigid Roof Mount
-Rigid SRCW 40" light bar (Roof)
-Rigid SRCW 20" light bar (Front Bumper)
-Rigid Dually Hyperspot Pair (Inside Front Bumper)
-Rigid Dually Hyperspot Pair (Front Bumper) (Orange)
-Rigid 10" SR2 Diffused (Rear Bumper, Dimmed)
-Rigid Dually Diffused Flood Pair (Bedside, Dimmed)
-Heretic Studios Cube Lites Pair (Mirrors, Dimmed)
-x_mods Custom Under Rail LED Strips
-LED 3rd Brake Light
-JLC LED Reverse Lights
-x_mods Custom V-LEDs Under Hood Lighting
-x_mods Custom V-LEDs Footwell Lights
-x_mods Custom V-LEDs LED Courtesy Lights in Mirrors
-x_mods Complete Custom Light Wiring (7 Switches, 15 Fuses, 18 Relays)
-x_mods Custom Relay Tray
Drivetrain:
-Radiator Cooler Bypass
-Filter Mag Transmission Magnet & Rear Differential Magnet
-2014 OEM 4WD RE5R05A Transmission w/Torque converter
-2014 OEM Transfercase
-2014 OEM Front Driveshaft
-2014 OEM Rear Driveshaft
-2012 OEM R180 Front Differential
-Lokka R180 Front Diff Locker
-PRG Poly Transmission Mount
-Nisstec TS Extended R180 CV Shafts
Suspension & Tires:
-Radflo 2.5 Non-Resi TS EXT (full custom valving)
-Bilstein 5125
-PRG 1" Top Plate Spacer w/Extended Radflo Studs
-Moog Titan LCA (Orange)
-PRG TS Adjustable Upper Control Arms (Orange)
-Retrofit Tacoma All-Pro AAL
-PRG Adjustable Shackles (Orange)
-PRG 1.5" Rear Lift Blocks (Orange)
-PRG SS Front Brake Lines
-4x4parts SS Rear Brake Lines
-Sway Bar Delete
-PRO-4X 16" Wheels (PlastiDipped)
-285/75R16 Hankook Dynapro MT
-High Polish .44 Magnum Valve Stem Caps
-2.5" Rear Wheel Spacers (to match the TS)
-4x4parts Poly Leaf Spring/Sway Bar Bushings
-808UpFront Custom Wheel Badges (Orange)
-Painted Spline Lug Nuts (Orange)
Armor:
-SHROCKWORKS C200 Skid Plate (Orange)
-Painted Factory Tin Foil Skids (Orange)
-x_mods Custom Tube Front Bumper
-x_mods Custom Tube Rear Bumper
-x_mods Custom Dual Front Recovery Points
-x_mods Custom Sliders
Performance:
-Injen Power Flow Cold Air Intake (Orange)
-Intake Manifold Spacer (Orange)
-Painted Valve Covers (Orange)
-Bully Dog Triple Dog GT
-Odyssey 34R-PC1500T Battery
-Variable Charge System Bypass (Constant +14.1V)
-VAIS Bypass
-K&N Oil Filter
-Dual Filter Mag Oil Filter Magnet
-Royal Purple MAX ATF/5W-30/Gear Oil/Purple Ice
-350z OEM T-stat
-Stillen Light Weight Under Drive Pulley
-Dynomax Cat Back (Black)
-Dynomax VT Muffler (Black)
-x_mods Custom Exhaust Dump
-Custom Saikou Michi Oil Catch Can (Orange)
-x_mods Custom Oil Catch Can Mount
-Clutch Fan Delete
-Dual 12" E-Fans
-x_mods Custom Dual E-Fan Shroud
Audio:
-Pioneer AVH-P3200DVD Head Unit
-Pioneer ND-BC4 Back-up Camera
-Alpine PDX-V9 Amplifier
-4x Polk Audio db5251 Component Speakers
-New Model Alpine R10
-SO Ported Box
-Rockford Fosgate Wiring
-x_mods Custom MDF Speaker Adapter Plates
-Baofeng BF-9500 Mobile 440 Transceiver
-x_mods Custom Mobile Radio Console Mount
Gear and Other:
-JetBeam BC10 (808UpFront Custom Engraved)
-Pelican Case w/2x Surefire G2
-Pelican First Aid Case
-Pelican Survival Case
-Fenix HL21 Headlamp
-Pelican 2745 Headlamp
-Pelican 2755 Headlamp
-Hotech True 5mw Astronomy Green Laser w/Red Light
-First Aid Kit
-Signal Mirror
-Leatherman
-Other Random Survival Stuff
-Fire Extinguisher
-Hatchet
-4AWG 17ft. Jumpers
-20' Hook Tow Strap
-20' Loop Tow Strap
-3x Smittybilt U.F.O. L.E.D. Safety Lights
-1 Gallon Folding Gas Can
-1 Can Fix-a-Flat
-Wrenches
-Clothes
In Progress:
Uh, 6-Speed swap??? I dunno I'm out of stuff to do...
Future:
-It Never Stops :D
-808UpFront Custom Steering Wheel Badge
-LT Headers
-B Pipes
-Rear Locker
-Illuminated Steering Wheel Controls
-Pathfinder Window Controls
-Oil Pressure Gauge
-Oil Temp Gauge
-Trans Temp Gauge
-m226 Swap (if I can find one cheap enough)
-More LED's
Day 1:
Wiring the Mirrors
Tailgate Wrap
PRG Shackles
Spindles
Rear Diff Filtermag
V-LEDs Dome/Map Lights
Stinger and Relocated VDC Switch
I thought I would go ahead and start a build thread, better late than never. Nothing too extreme, I just love to turn wrenches!
Discussion Starter · #2 · (Edited)
Moved and Rewired the Amp
Back at the Beach
Sold the 7089's and Plastidipped my PRO-4X's
Wash, Clay, Polish, Wax, Wax, Wax..
Under hood lights
Foot Well Lights
Doors Lit
Modded the Plate Bracket
Painted my Dually's
Building my Mounts
Powdercoated
Mounted
Front Burger
Royal Purple
Painted IMS
Had my alignment done today.. Now I NEED some 33's. (Attached pictures)
About time you made a thread. :ugogirl: Love this truck and I want those projector headlights
TOTM right there ^.. (but you do need some 33's)
Btw you said you installed the spindles, but what are the upper arms? And are you at 6" or 8" now?
justin: Thanks! I love my lights too, very proud of them :)
Abeachbum: I'm honored! I need to get some better pictures, once I get 33's, my 31's look a little sad..
I have PRG UCAs that I painted orange when I took them off to clean a while back. The truck sits at about 6.5" right now and I can't go any higher if I want to fit in the garage. I am going to lower the roof lights for the 33's and if I can get them low enough I'll add a 1" body lift!
Okay, I just finished my last essay of the year!! So one last picture before I hit the hey.
After my last final on Wednesday, me and my sister are hit'n the beach then I'm all over these new FX-R projectors. They should be a good improvement over the Morimotos.
It's looking great man! Throw some 18's and 33in. tires on it, and you've got my vote for TOTM right there! :)
Hey FrontierNation,
Thanks! I your truck is look'n good too! We have the same head unit!
I want some 17's for the 33's.. If I can sell my A/T's, get some M/T's, and still have enough dough leftover, then I'll get some new rims. Otherwise I'm painting the PRO-4X wheels black and mounting the mudders on them!
Definitely get yourself some 33's, that will really complete the look. You've done a good job. The very first picture you posted in this thread is sick..what camera was that, looks really wide angle..almost fish eye because of the curves.
Discussion Starter · #10 ·
Thanks! It was a fisheye, a Rokinon 8mm mounted on my Canon 50D, and I was only about 2 feet away from the truck at the time. I had just gotten cleaned up to go to a Christmas party so I could use the good camera :D I love the lens, it's so much fun! 170 deg. view angle!
Hopefully I'll get the tires before the years up.
Here some more pics I took at the same time. One of my friends bike and one of my sister's "xmas hippo", not with the fisheye, but still she is very proud of it.. All that mattered to me was that I got to use my star filter..
^nice! Super clear/crisp shots. Post up in the photography section!
Check out this one of Jupiter. Me and my friend took this using my camera attached to our school's telescope a few weeks ago.
I'm going back tomorrow night to use the faulkes and our telescope/camera. Hopefully we get Saturn!
I'm going back tomorrow to use the Faulkes North and our telescope/camera tomorrow night. Hopefully we get Saturn!
Holy crap that's awesome!
Pic of Jupiter is awesome dude! On a side note, what camera do you have? These pics are just amazing, to say the least.
1 - 20 of 971 Posts
