1 - 3 of 3 Posts
Hey, looking for some used after market frontier UCAs for my newly acquired 06 Frontier. Hopefully somebody did a Tswap and still has the UCAs from their previous lift taking up room in their garage.
SPC make some nice uca's. They run about $500 a set and will come with the 1 upper bolt that you probably will need to cut. It's on the driver side back. They also come with an adjustable ball joint, which makes alignment much easier. Google discount coupons or codes for them and you'll probably find something. I found a place that required you to email them asking for the 10% discount code. I believe they were also shipped free.
You might also want to go with a set of lower cam bolts to aid in alignment.
Set the rear bolt to push the arm out and the front bolt to pull it in. This will give you about an 1" of additional tire clearance at the rear near the pinch weld.
Good luck
1 - 3 of 3 Posts
