1 - 13 of 13 Posts
i made a mistake on lifting my truck with the PRG mini lift. i added two inches in the front and rear which of course left me with the factory front rake. i was wondering if anyone had a set of stock leafs from an 2007 crew cab nismo that they might want to sell/trade. on the trade part, my leafs got the 2" deavers from prg. so just a thought. the reason i need a set of leafs is because i had a shop put my deavers on and never gave me my extra parts back like the overload leaf.
your location?
did u try going back to the shop that did the work and askin for your parts??
your location?
im located in Augusta, GA.
I have the overloads too! Sitting in the garage doing nothing but taking up space!
do you by chance (or anyone) know if thats all thats removed from the stock leaf springs for the PRG Deavers??
Im not even going to bother. i had the lift done in mid June.
If I remember right when I did mine... yes, that's all that's taken off.
Just a thought though.... the rear does sag after a while. I actually had to put in a 1" lift block to even it back up with the front.
It sags with the Deavers? Or after you added the cap?
I noticed a sag in the deavers. I had the cap since I got the truck (only put it on in the winter, can't fit the bike in the back, don't use the bike in winter). I've had the deavers in since May 08 and noticed a gradual difference. However, I do use my truck as a truck. The bed is used for dirtbikes, axles, recycling/dump trips, cinderblocks, firewood, and even towing my 17' dovetail trailer so I'm not surprised they sagged. Can't forget they have to endure 4x4ing where they get fully spring and unsprung countless times.
Just saying that I think you should hold out replacing them so quickly and see what happens.
Discussion Starter · #10 ·
o okay i understand now. your saying that the deavers will get broken inn after a while. ok gotcha. well my problem is that my truck doesnt get used as a truck ha (it hurts to say that ha). it does the off roading and all but i have never pulled a trailer behind this truck yet. the only thing that has been in the bed of my truck is lawn equipment (push mower and all that jazz) but never had anythng over 80lbs in the bed.
with that said, using weight to break in the deavers, what if i took my 22ft dovetail trailer with my john deer tractor and just put enough weight on the hitch (using the wheel crank to adjust) to make the deavers stress a little. maybe keep it in that position over night?
Discussion Starter · #13 · (Edited)
I have no use for them so they can go, I have the factory Nismo Bilsteins sitting there too. Right now I am in Central FL and the stuff is in the panhandle. PM me if I can help ya
i went ahead and sent you a PM. thanks
1 - 13 of 13 Posts
