1 - 20 of 25 Posts
2001 manual v6 crewcab
I turned it on idled perfect around 800rpm drove it to my grandmothers turned it off went inside for five minutes came back out hit clutch turn the key and nothing just turning over doesn't start that is crazy! I am so glad I live a block away from my grandmothers this is ridiculous. has this happend to you?
So is there any cranking? Dead battery try to jump it with another car, if it starts it's the battery. If it cranks and doesn't start check the fuel pressure hose and put your ear up to the gas tank see if the fuel pump runs.
the engine turns over with no problem so not battery i checked for spark and i dont have spark on any cylinder so i bought a new ignition distributer i am pretty damn sure it is that fuel pump also turns on so it isn't that. I update when i install the distributer i really hope i dont lose 60 bucks
Is the distributor rotor turning when you crank the engine? If not, broken timing belt.
1 block away - even if you had walked, this would've happened soon anyway !
My daughter's 1998 Pathfinder with V6 engine had a bad distributor, I replaced that to fix.
WELP THATS IT THIS TRUCK WON'T START .....................
checked all fuses changed the whole distributor and nothing no spark i am so pissed i bought this piece of **** in march and its already dead ****ing incredible 92k miles ridiculous i am sooooo heated!!!
Cranshaft position sensor? TPS? Could be a lot of things. Probably not getting fuel. Check fuel pump.
Discussion Starter · #10 ·
fuel pump is fine crank sensor is a ***** to get to we tried today and failed my neighbor has a mechanic program that tells him the steps so we are waiting on that we hope its the crank sensor what is the TPS?
TPS is your throttle position sensor. It should be blue with 2 plugs in it, connected to your throttle body. If that failed you're truck aint gonna start. Run a little copper wire out the center of the top plug. Put a voltage meter on it, turn your battery on. Loosen both screws on top and bottom and rotate it until it's about .50.
Discussion Starter · #12 ·
i will try that thanks a lot for the idea will update when neighbor is ready to help again......
The TPS will not keep the engine from starting. If it's disconnected, the ECM will go into a default mode, which is how you adjust the base idle and ignition timing without a scan tool. If the distributor wasn't a genuine Nissan part, it could be that. A bad crank position sensor, bad ECM or an open/shorted circuit or high resistance in the circuit could also cause a no start. Anyone can replace parts and hope that it will fix a problem, but if one guesses wrong, it can get expensive quickly! To properly diagnose the problem, one needs to refer to the factory service manual and follow the diagnostic steps in it for a "no start/no spark" symptom. It also wouldn't hurt to check for any stored trouble codes. NissanHelp.com has loose service manual sections available for free download in their "knowledge base" section (complete manuals require a subscription). The "EC" engine control section would have the diagnostic info for ignition system issues. Nico Club's website also has service manual downloads at their site.
Hope it works out, but, remember, a crank position sensor code often, but not always, means the sensor, itself, is bad. It could be a bad connection or circuit issue or even a bad ECM, albeit rare. Hopefully you order a genuine Nissan or Hitachi sensor; I've run into a lot of issues with aftermarket and/or non-OE cam and crank position sensors on Nissans.
Discussion Starter · #18 ·
now we cannot reach the position crank sensor....................... Tommrow a mechanic friend is coming to see if he can do it but I doubt it that thing is wayyyy up there behind the firewall I think I am going to have to take it to a shop this is ****ing bullshit
Discussion Starter · #19 ·
any update on this one, I'm curious.....
SHE LIVES AGAIN!!!!!!!!!!!!!!!!!!!!
turns out it was the cam shaft position sensor on the distributer and not the crankshaft I got it confused because I am a fool the pins on the new distributer got bent upon install and we straighten them out put it back on carefully and thats it bam life was restored! thanks everyone for the help
GREAT:excellent:
1 - 20 of 25 Posts
