I'm going to replace the leaf spring bushings on my 98' 2wd. It will be my second job, I have done it before on my old hardbody that I use to have. Not a hard job, but it does give back the old load capacity. I use my truck for work and it drops alot in the back with any load, hince the need to replace my bushings. I usually carry light loads, but still, it looks like crap when you put 500lbs in the bed and the front rides high but the rear is down low. So, does anyone want me to make a write-up about the process with pictures?
