I have a '13 2WD & Im pretty sure I have the WOT restriction. I can nail it from a stand-still & the power doesn't really come on till I hit somewhere around 20-40 mph. I also run Torque Pro & I have it set to see the percentage open of the butterfly valve in the throttle body rather than the percentage down that I'm pushing on the skinny pedal. Although I havn't logged it, the widest it shows the butterfly valve being open is 89.4%. Now, Im not sure if that would be considered "WOT" or not, buuut seeing how it doesn't show it to be 100%, I'd have to go with, no.2013 was the year it was removed from the factory. Only way I've ever heard to remove it on previous years is a tuner or an UpRev tune.
I don't know, bdhaeh. I mean 10% left for the butterfly to open is quite abit. Don't ya think? After I first start my truck & its still in 'warm up' mode Torque shows the valve to be open roughly 5%-6%. Once the engine is up to temp it settles out right at 3%, give or take a few tenths of a percent. So, IMO, another 10% should be a pretty noticeable difference. I'm not saying you're not correct, Im just throwing my thoughts into the ring to see what you or others have to say about it is all.Roughly 90% on the tps is WOT.
If youre asking about what it shows on the Torque app, it has several sensors to choose from, such as accelerator sensor A, B, C, etc. Certain sensors have a blue question mark off to the right of them that further explains what information that sensor is showing. I cant remember which sensor I picked, but it's supposed to be the one that shows the percentage the butterfly valve in the throttle body is open, not the pedal itself in relation to how far down I'm depressing it.Is the Throttle Position Sensor reading the % that the accelerator pedal is depressed, or the actual % of 'butterfly' w/in the throttlebody?
What yr Frontier are you running?I tuned back to stock to check it and my gas mileage which is terrible tuned and not.
Stock at idle my tps reads 1%. Punch it and it jumps to 80% then immediately comes back down to 60% then jumps back to 80% after 40 mph.
Tuned it stays at 80%.
This is from the data logging from my cortex.
There is a shop here in Vegas that does Uprev but I can't remember what it's called. You can always order a Bully Dog tuner or something equivalent from Superchips etc..Now the real question. Does anyone know someone in Las Vegas that can do this?
Sent from my SM-G930T using Tapatalk
Fair to say your '14 felt a bit more responsive in stock form when compared to your '06 & '11?'13 and up no longer have the restriction from the factory. My '06 and my '11 both had it, my '14 does not.
With the BDGT, once the restriction was removed I got 100% TPS angle from idle at full accel on both previous rigs so not sure why you guys are only seeing 80%.
As described above, if you still have the restriction, you will only see 60-70% throttle until you reach 40mph. It's a noticeable jump at 40 mph if you put it in manual 2nd and just stomp on it.
With the BD gauge set up to read TPS angle mine reads live TPS%. It goes to full throttle (100% TPS angle) from a stop when I put it on the floor. Maybe there's a different set of programming parameters on the Superchips tuner and TorqPro app that explains why you're only seeing 80%??
