I have a 2010 CC SE 4x4 automatic transmission.
I was pulling my boat this morning and the transmission wouldn't shift to the next gear. I think I was in 2nd and it wouldn't go to third.
Here's the details. Pulling a ski nautique which is about a 4000# load. Entering a freeway with an uphill entrance ramp. Gave it the gas pretty good, but not floored. I was probably about 35-40mph and the rpms got up to over 4k and it wouldn't up shift. I backed off the accellerator then applied more lightly and it shifted. After that everything was fine.
This is the second time it's happened. It's happened before at the exact same spot. Some combination of the load, the grade, the speed is making the transmission not want to shift.
It was a strange morning. The boat started fine, then ready to take first ski run and wouldn't restart. Had to swim it back to the ramp. Put the trailer in deeper than normal because of no engine to push up on the trailer. Tried to pull out in 4wd Hi and slipped back into the water some more. That was a little scary. Put it in 4wd Lo and pulled out fine. Sure glad I got the 4wd and that's exactly why I did.
Then on the way home, once on the freeway a bird misjudged where he was going and glanced off my hood and bent my antenna.
After that, got home fine, but didn't get to ski.
