Okay, the SLIP and ABS lights are still on and now I cannot get her to go into four-wheel drive. The four-wheel drive indicator flashes the front wheels but it never engages. I would rather not have to go to the stealership shop if I can. I did trace the ABS wire back from the wheel that I took off when I replaced the alternator and they look fine, at least to me, it is attached at least. I did disconnect the battery and performed the reset procedure for steering alignment but to no avail, the lights are still on, it has been over two weeks. Bucks are tight right now but do not want to bugger anything up, if that is possible with those lights still on. Any ideas for me to try before I have to give in and be presented with a large bill from Nissan?
