1 - 18 of 18 Posts
2022 frontier s crew cab 4x4 and 2000 frontier xe crew cab 4x4
Hello ladies and gents,
Purchased the harness to go with my after market class III hitch for my 2022 Frontier S Crew Cab 4x4
I'll attach pictures for y'all
Make sure you check out nissans instructions on www.nissan-techinfo.com so you do not set off airbags or fry your system, select Accessory Instructions then year, model, accessory type and so on.
From The City of Brotherly Love and Sisterly Affection, Philly
Rafael Hernandez
Material property Eyelash Jewellery Eyewear Body jewelry
Automotive tire Tire Bumper Finger Material property
Hand Finger Wrist Personal protective equipment Body jewelry
Material property Technology Electronic device Cable Electronics accessory
2022 SV CC 4X4, Glacier White
You can pick one up at your dealer since they are now in stock, save shipping and has all the parts, relays etc and all Nissan oem
I'll check with my dealer. Didn't have it last Saturday. You mentioned relays. I have the tow package minus the hitch and plug/harness. I thought this harness was simply plugged into the existing connectors zip tied to the frame?
Yes that is one part but you also need to connect a second harness and two relays inside behind the cab passenger front kick on the door hinge side
Rafael Hernandez View attachment 337661 View attachment 337662 View attachment 337663 View attachment 337664
Hi Rafael, I have a new 2022 Frontier and I'm getting the runaround like u can't believe. The dealer says there is no adapter harness made yet so I can't hook up my Curt controller that I removed from my 2016 Frontier. Is the white plug that sticks out at the top of the left kick panel, is trhat where the adapter harness would tie in? If so I could cut that off and splice in my old 4 wire harness. FYI my Frontier came with the trailer hitch.
Thanks!!
2022 Frontier SV LWB 4x4
Thanks!!
If your trying to connect your brake controller it should plug in to the connector under the steering column similar to your 2016.
Did you have to cut out a place on the bumper plastic area to get the plug to snap to the bumper?
OK, There is no pigtail to ty in an adapter harness under the steering column, even the service mgr can't find it. The parts dept has a diag that shows the pigtail under the lower left dash panel. That being said there is still no factory adapter harness avail. So do this-------order the CURT Blue tooth setup, plug it in to the recepticle in the bumper, plug in the trailer,download the CURT APP follow the directions and binggo your done.Now all the brake settings are on your phone. Works very well.
Not sure why you can't find it. It's just above the parking brake pedal on my 2022 SV. I ordered the harness and controller from etrailer. I'm installing it today.
Automotive tire Motor vehicle Vehicle brake Bicycle part Alloy wheel
Land vehicle Tire Automotive tire Helmet Wheel
‘22 CC Red Alert 4x4 S
I bought the hitch and the harness from a local dealer. Much cheaper than anywhere online or local places that did the installation. Yea I had to cut out the bumper. They supply a template, or you can cut from the underside as there is a perfect outline “cutout” in the metal body panel the bumper is covering. Done in a max of 2 hours and that’s with drink breaks. (and I’m a chick)
just follow directions on the techinfo page mentioned and you’re golden
Reactions: SuperDave1
1 - 18 of 18 Posts
