Thanks in advance again. I ordered blue LED lights for my interior of a 2012 PRO 4X, and it came with two extra bulbs for the license plate. I don't want to change that from stock so thinking I can grab some cheap bulb sockets for these and install them in the footwells. I just need to know what wires to tap into. I was thinking of tapping into the map/courtesy lights but don't want to run wires from there if I can avoid it. So where do these wires go? A post driver side?
Just got done adding the remote tailgate lock by tapping into the rear door lock wiring, thanks for all the ideas.
I would tap into the cabin light circuit at the BCM (just above your brake/gas pedals). Either pin 50 (cargo light) or 63 (interior room). IIRC the BCM is providing a ground to the circuit, but be sure to test.
Thanks for the quick reply and please forgive my ignorance. So if I understand this, to install lights I need to provide a constant positive to these lights and then tap into the switched ground wire? If this is true, is there a wire I can tap into for the constant power? Also, what wire is 63 on the BCM? Will it be the same color as the wire at the map/courtesy light?
BCM pin 56 supplies "battery saver" protected +12V to the interior cabin lights. If you forget to fully close a door, for example, pin 56 will turn off after 10 minutes, preventing battery run-down.
As mtyler11 said, BCM pin 63 switches to ground whenever a door is opened, so is the correct wire for the negative side of the LED bulbs.
I was already running a microphone wire for Bluetooth phone, so found it more convenient to tap these wires at the room/map light assembly, as opposed to folding myself under the instrument panel, to provide power my foot well LEDs (2011 SV king cab). The A pillar trim garnish is easy to remove and reinstall; I used cable ties to fasten my wires to the existing factory harness run there. However, you do have to be careful not to disturb the air bag mounted behind the A pillar trim (disconnecting the battery first reduces the risk).
I have assumed you prefer the foot well lights to turn on with the dome lamps. If no, the wire recommendations will be different.
Take pleanty pf poctires pf the install and finished product please
Sent from my iPhone 7 plus using Tapatalk Pro
