My fluid tank has sprung a leak. How do you access it? It seems to be tucked up in the front fender. Just remove the screws holding the plastic in the wheel well?
Thanks in advance.
Thanks in advance.
Where did you locate the 2010 service manual? I have a 2009 but would like to get my hands on a 2010 version.I just looked at the service manual instructions for the 2010 - Im assuming the 2006 would be similar.. It says to remove the front fender protector to get access to the washer hose, sensor and motor connectors - and then there are two screws under the fender that need to be removed to pull out the tank.
Check your PMs.
