1 - 2 of 2 Posts
Alright, so I've had my 2007 Frontier SL for about two years. Pushing 200k miles. Recently, I've started having problems with both front windows.
Front passenger side doesn't roll down from either the driver's side switch or the passenger's side switch. Works fine rolling up. Since it doesn't work from either switch, I've ruled that out. I've replaced the motor, actuator and relay. Didn't fix the problem. I have no idea what could be causing the problem; hoping someone out there has an idea.
Front driver's side rolls down fine, but has a lot of trouble rolling up. I usually need to pull on it to help it on its way, and even then it barely gets up (yeah, I know. Phrasing). This started about two weeks ago and I haven't had time to take any corrective action yet.
While I'm at it, I might as well add that it will upshift pretty hard from time to time. Haven't managed to notice any common trends when it does. Seems to be at random. And there's a tinny rattle that shows up infrequently when I'm accelerating.
My driver side one stays down and wont come up if it goes down all the way. To get it to roll up though if you are holding the switch up and slam the door it rolls up. There is a thread somewhere on here with more details on what the exact problem is that causes it to do this.
Sent from my SM-G920W8 using Tapatalk
1 - 2 of 2 Posts
