1 - 17 of 17 Posts
2017 Pro-4X w/Luxury Package
First hot day of the season. Took a 25-mile drive, mostly interstate.
Had the A/C on, noticed a huge reduction in power. I don't think I've ever had a vehicle that exhibited such a noticable impact from having the A/C compressor engaged.
And gas mileage, i get 17-18 around town, 25 to 50mph, and if we have a hot spell where I'm doing the same driving with the AC i get around 14. My gas mileage went up a lot when I put the Magnaflo and the K&R intake with a throttle body spacer, but the AC still robs the power, even after mods.
Maybe a retrofit with a modern compressor would help?
The one thing that I've heard about, is modern cars have a relay that shuts the compressor down at a certain power, so that when your pulling up a long interstate hill the compressor would shut off. Basically a relay that shuts the compressor down when you need power most. This relay started showing up at around 2000, but is standard these days. I don't know how it could be done, on ours, but it's been done before on others. We need an Electrical Engineer stat!
I've had a '98 Frontier for 13 years now, and a 2004 Frontier for 5 years; both are 4-cylinder 5-speeds, and I don't notice the same. Mine are the original compressors, and the AC gets used a ton here in Arizona. It's not like I have a practice of turning off the AC to go up hills either.
I love the way my truck responds when I hit the pedal, but there is no doubt I feel like I'm driving in mud when the AC is on.
I use the ac like an engine brake if I'm going down a steep hill it will definately slow me down so I can use less brakes
Same if I'm pulling out onto the highway, I turn it off right before I take off so I don't slow everybody down
I use the ac like an engine brake if I'm going down a steep hill it will definitely slow me down so I can use less brakes
Maybe get a 4-cylinder 5-speed 2WD truck? I know my daughter's 4WD '98 Pathfinder with VG33 and automatic is no racehorse, but figured extra weight of 4WD and Pathfinder body had something to do with it. A co-worker who had a 2002 4-cylinder Frontier King Cab with automatic claimed his was a dog as well; maybe the automatic transmission shift points????
Was just looking at numbers and was very surprised. The L4 in a 2wd extended cab 5 speed, has almost the same HP to weight ratio as the V6 with auto and 4 WD. I have been looking for another 1st gen, and I will think about the L4 with 5 speed, and had not even considered it before.
Had to go to a graduation party and it's about 95 here, so I manually shifted my trans at about 200 rpm's above the auto shift points, huge difference! That little bit bogs it down just enough, doubt I will bother, but if I ever need trans work, I might look into it.
I drove my 2004 King Cab 2WD 4-cylinder, 5-speed 200 miles yesterday, mostly on highways (this weighs more than my similarly-equipped '98 regular cab). So I intentionally tried turning the AC off and on while driving, on straightaways, downhills, and uphills, and if I didn't know I was pressing the button, I wouldn't have had any idea whether AC was switched on or off.
So my guesses for the difference - which I do believe are real - are still:
...automatic transmission design
...engine design
...are the same AC compressors used on the two engines?
Maybe someone with a manual transmission and the V6 can comment about whether they have the same issue.
Last week I did a 500 mile RT including some lower elevation passes. One 6% grade had me down in third gear, once; otherwise fourth handled them all. But I turned the air off on long or steep uphill grades. There's no way the truck would sustain 75mph speed limit with the A/C on on even moderate grades.
On steep downhills I always turn the air on in warm weather too.
Yes, sometimes on steep uphill highway grades I do have to downshift into 4th gear on mine. On highways I typically use the aftermarket Rostra cruise control in my 2004.
My aftermarket CC will disengage when the speed differential gets too great. Set at say, 79mph, when the truck slows to 64mph on a grade the cruise will disengage. At that point it's time to shift down into 4th gear anyway so it works out well.
Ac power reduction.
When I first purchased my 2004 2.4 XE I hardly noticed the ac kick in. But over the last few years it felt like it was robbing half the limited hp the truck has. I charged the ac refrigerant and now it feels like a different truck. I think overtime the hoses degrade and you slowly lose refrigerant. This low level of refrigerant causes the ac to cycle constantly when your ac is on and robs hp.
I'll have to double check my facts, but I believe the fan clutch may play a part in this as well. If it's hot enough for the compressor to run non-stop, or disengage all together, than it's a safe bet it's hot enough for the clutch to engage. The two of them acting together would cause a very noticeable drop in both hp and gas mileage.
I'm told converting to an electric fan does wonders.
I remember an article some years back in Car and Driver I think. The horsepower cost of running the A/C compressor is about 10-14HP on average. That would cause a noticeable difference with A/C on or off in almost any vehicle. I know that my 4-banger has a compressor cutout. At about 75% throttle, the compressor cuts off until you back off the throttle. I don't know if the V6 does the same, but I would assume so.
1 - 17 of 17 Posts
