Fighting my hard start issue when the engine is hot. Cranks fine but takes a while to catch, as if it's flooded (but no smell of gas under the hood or in the oil).
One possibility is that the coolant temp sensor is bad, which tells the ECU the engine is cold, causing it to dump a lot more fuel into the engine. Hence the difficulty starting.
Believe it or not, you can actually get to the coolant temp sensor (unlike almost every other sensor). But there's two... one small and one big.
Anyone know which is the one the ECU uses to control the fuel mix?
