They do, check Amazon or eBayDo they make valve extenders so we could check pressure or add air while valve up?
Facing up so the valve can’t get damaged by anything. I’d imagine that’s why they put it that way and in years past we had alloy spare wheels to match.
Facing up (OEM style to protect the air valve) and with a hard cover on top to protect the tire sidewalls from getting dented/damaged by the chassis cross members.
interesting,i noticed my spare was low on pressure when i bumped against it the other day but didnt even look to see which way it was mounted. i would say there is definitely a trade off: mounted face down you can easily air it up, but you're also exposing the face to road debris, for that reason i'd probably face it up. how often do you air up a spare? i never have in 24 years of owning over 10 cars. now i'll probably get a flat. lol
I had a valvestem extender on a handtruck at work, a vehicle maintenance tech provided it and said it would make airing-up easier. Caught it on a curb and it tore the valvestem off the cart's wheel and instantly deflated it.I see Harley Davidson has one that appears to be the longest in pictures, I’ll call and ask for length.
Face down exposes the face of the wheel too. Either way will still "dent" the tire without something in between (thus why I put a hard cover on).I put my spares face-down for now, opposite of factory. I lowered the wheel for the first time yesterday, and the outer face of the tire itself was deformed where it had been pressing on the frame and mounting since it was originally delivered, and there were some small rocks sitting up there. Pressure-washed the face (it was also a bit greasy) and turned it over faced-down to put it back.
There might be a little more possibility of damage to the valve stem, but I figure anything that would damage the valvestem recessed an inch into the wheel compared to the sidewall would probably damage the sidewall too, so the tire would be damaged regardless. The ease of checking the spare tire pressure and correcting at each oil change offsets any mild risk for valvestem damage.
When I had it down I liked the look of the factory steel 16" wheel. I'd honestly be half-tempted to go with four of those steel wheels if I was doing serious offroading, since the steel wheels are more likely to simply bend instead of breaking on the trail, and wouldn't gouge as severely if dragged on rocks as the aluminum wheels would.
I won't use valvestem extenders anymore.
I'd be more concerned on a FWD or another vehicle with a lot of positive offset where the face of the wheel sticks out further than the tire sidewall. On my truck, backspacing on a 7" wide 16" wheel with 40mm offset is approximately 5", so approximately 2" backset at the mating surface of the wheel, add another half-inch for the width of the bead of the rim, plus the tire itself sticks out at the sidewall over an inch and a half (265mm section-width is about 10.5 inches), it's not impossible that I could hit the front face of the hub of the wheel, but it's pretty unlikely. If I were that concerned I'd probably buy or make something that could be bolted to the wheel and protect the wheel and tire even if it scrapes. Or for four wheeling trips I'd move it to the bed if I was that worried and needed access easily.Face down exposes the face of the wheel too. Either way will still "dent" the tire without something in between (thus why I put a hard cover on).
Like the cylons? ::grin::I'm actually shopping for tire valve extenders now for my spare, I have a plan.
I referring to an extender that I can reach in and check spare, air up if necessary and tuck away again.I put my spares face-down for now, opposite of factory. I lowered the wheel for the first time yesterday, and the outer face of the tire itself was deformed where it had been pressing on the frame and mounting since it was originally delivered, and there were some small rocks sitting up there. Pressure-washed the face (it was also a bit greasy) and turned it over faced-down to put it back.
You can used your recently installed utility track to strap it down.Or for four wheeling trips I'd move it to the bed if I was that worried and needed access easily.
Nothing but the rain.I'd be more concerned on a FWD or another vehicle with a lot of positive offset where the face of the wheel sticks out further than the tire sidewall. On my truck, backspacing on a 7" wide 16" wheel with 40mm offset is approximately 5", so approximately 2" backset at the mating surface of the wheel, add another half-inch for the width of the bead of the rim, plus the tire itself sticks out at the sidewall over an inch and a half (265mm section-width is about 10.5 inches), it's not impossible that I could hit the front face of the hub of the wheel, but it's pretty unlikely. If I were that concerned I'd probably buy or make something that could be bolted to the wheel and protect the wheel and tire even if it scrapes. Or for four wheeling trips I'd move it to the bed if I was that worried and needed access easily.
Unless you have a hard cover on it ::wink::I referring to an extender that I can reach in and check spare, air up if necessary and tuck away again.
You may do as you wish but either side will get frame cross bar dimples.
that's a possibility, though I'd probably put the side tracks on and do like bbaker06 did:You can used your recently installed utility track to strap it down.
