Looking for advice and i appreciate your time & help!
2000 CC w250k
I replaced the OEM unit about 1 year ago with a Rockauto Cardone brand ($86?). It never seemed "right" from the start, cant really pinpoint the difference but ever since it seems when starting the engine would fire & the starter would release the flywheel & spin-out. Then I try again. Now its become a real issue, will hardly engage/crank the engine long enough to start it.
Im not sure what to do except to revert to what was done last. Distributor.
RA has a Hitachi Dist for $223.00-ish?
You guys have any input on this?
More info:
knock sensor is the only code i have.
after a difficult start i have really rich fuel smell from the exhaust
i think my flywheel has sustained some damage (gonna fix that last I hope)
i think my injectors are leaking down partially causing the starting delay issue
timing belt is due again
looks like typical problems with a 250k vehicle, right?
thanks from Bama the college football capitol of the world (for now)
2000 CC w250k
More info:
