1 - 3 of 3 Posts
I haven't had the chance to go through the manual.
like the subject title states.
I noticed a black cylindrical piece but at the end it has the metallic cap.
and where is the drain bolt?
drain plug is right at the back of the skid plate and there is a lil plate near the front of the skid plate that has 2 10mm bolts holding it take them out and there is the filter
yes, you have to take off the plate when you remove the oil filter, but i found it was easier to access the filter with a wrench from the side by the passenger fenderwell,
and just look for the bottom of the oil pan. the drain plug is on the right side at the bottom
1 - 3 of 3 Posts
