1 - 20 of 35 Posts
What mileage did some of you new (as in brand spankin new!) truck owners do your first oil change at?
Always do the first at 1000 miles, second at 3000, then every 3000.
2020 Toyota 4runner TRDOR
lets see, second at 7365
third at 11,251
fourth at 14540
fifth at 18274
sixth at 22273
seventh at 27792
eighth is pending.
I believe in the first at 1500, then the second at 3k at which point i go syn. Change again at 6500 and then at 10000 at which point i go to a 5k interval. This may be a bit much but I am hard on vehicles and expect them to last.
Did first oil (blend) only at 1500
2nd - oil (full syn)and filter at 2150
will do every 5000 now or before and after winter - full syn and wix filter
on my 2001 Frontier i used Shaffers synthetic, and changed the oil every 5000 with all the highway miles i drive.
on my new 2010 i was told by the service tech, that every 3750 was recommended, and that is what i did. and they didn't see a need for synthetic, so i used their oil, Mobil 1. $44.95 every four weeks, fun, fun, too much fun.
Factory calls for it at 3750...I think I did it right around 3500 and I used Castrol dino. At about 7000 I did a semi synthetic blend. At 10k I switched to Royal Purple full synthetic
haven't done it yet. Have 2100 on the truck now and will get the oil and filter changed before I drive it to Charleston, SC at the end of the month. 1100 miles roundtrip. I am just eating into my warranty lol. Itll be 3500 miles in 2 months
I did it at 1,000. Will do it again at 5,000 and every 5,000 miles after that.
Had the dealer do my 1st free change at around 3400 miles. They did an OEM filter and Pennzoil 10w-30. I'm probably going to do it myself again with Pennzoil Platinum 5w-30 and a PureOne filter soon. I've got about 4300 on it now.
2020 SV 4x4
Wow thats the exact same process I use. Mobil 1, Pureone oil filter and air filter, every time.
I drive hard as well.
I think I did my first one around 600 miles (1000kms). Switched to synthetic and I do it every 6250 miles now(10,000 kms.)
1st at 2,000 using Castrol dino oil, then at 3115....Mobil 1 full syn since at 3-4 K intervals.
what about the special break in oil that the dealership is talking about? mine changed @ 2500kms and mobil 1 on 5500kms
Modern motors have higher tolerances so break-in periods are a lot shorter. Keep it in the crank for a little bit but then drain it out.
I like my process since it goes from break-in to dino to syn. My system is not written in stone or anything, it is just want I prefer to do. The use of dino vs syn is going to change your interval and it is up to the owner to decide what they are comfortable with.
I have to give props to the people in this thread. I was expecting this to become a dino vs syn thread or an I'm right, your wrong thread but it has stayed very civil. It is nice to see everyones opinions without having to worry about others picking you apart because of xyz.
1 - 20 of 35 Posts
