1 - 3 of 3 Posts
The other day I was out enjoying the rain in my truck and started wondering, at what point should I be worried about sucking up water from the RAM connected to the Volant intake?
The water and mud was not getting up too terribly high, but what do some of you guys with intakes do to keep the water out?
Edit: Want to note that I already drilled two holes at the bottom of the box to let water drain out.
Most add an intake sock and then if you are going to hit some extreme water/mud, then remove the RAM air portion and plug up the hole (some have said a spray paint can top works well).
yup I've use a wd40 can lid once after leaving my plug at home. This is what I just posted in Daves thread regaurding a Volant and snorkle.
1 - 3 of 3 Posts
